The DS600 temperature sensor measures its own temperature and outputs a voltage proportional to degrees centigrade. The voltage output has a +6.45mV/°C (typ) sensitivity and a +509mV DC offset, which allows negative temperatures to be easily measured and reported. The device's ±0.5°C (max) accuracy is rated over the 2.7V to 5.5V operating voltage range and a -20°C to +100°C temperature range. Outside this range it is ±0.75°C (max) accurate to -40°C and +125°C.
The DS600 also contains a thermostat function with a user-defined threshold and an internal comparator to ensure high-precision threshold detection. Low-power applications are easily accommodated because the DS600 has only 140µA (max) current consumption and has a shutdown mode with a current consumption of only 2.5µA. The DS600 is available in an 8-pin µSOP-EP package, enabling a quick thermal-response time in temperature reporting. Prices start at $1.80 (1000-up, FOB USA).
Full Data Sheet(PDF)
