Analog Devices Introduces D/A Converter AD5641
Analog Devices AD5601 AD5611 AD5621 AD5641
The AD5641, a member of the nanoDACTM family, is a single, 14-bit buffered voltage out DAC that operates from a single +2.7 V to +5.5 V supply consuming <100 µA at 5 V and is available in a tiny SC70 package. Its on-chip precision output amplifier allows rail-to-rail output swing to be achieved. The AD5641 utilizes a versatile 3-wire serial interface that operates at clock rates up to 30 MHz and is compatible with SPI®, QSPITM, MICROWIRETM, and DSP interface standards.
The reference for AD5641 is derived from the power supply inputs and thus gives the widest dynamic output range. The part incorporates a power-on-reset circuit that ensures the DAC output powers up to 0 V and remains there until a valid write takes place to the device. The part contains a power-down feature that reduces the current consumption of the device to <100 nA at 3 V and provides software selectable output loads while in power-down mode. The part is put into power-down mode over the serial interface. The combination of small package and low power makes this device ideal for level setting requirements such as generating bias or control voltages in space constrained and power sensitive applications.
Product Highlights
  1. Available in space saving 6-lead SC70 Package.
  2. Low power, single-supply operation. This part operates from a single 2.7 V to 5.5 V supply and typically consumes 0.2 mW at 3 V and 0.5 mW at 5 V, making it ideal for battery-powered applications.
  3. The on-chip output buffer amplifier allows the output of the DAC to swing rail-to-rail with a typical slew rate of 0.5 V/µs.
  4. Reference derived from the power supply.
  5. High speed serial interface with clock speeds up to 30 MHz.
  6. Designed for very low power consumption. The interface only powers up during a write cycle.
  7. Power-down capability. When powered down, the DAC typically consumes <100 nA at 3 V.
Applications
  • Voltage level setting and bias generation
  • Digital gain and offset adjustment
  • Programmable voltage and current sources
  • Programmable attenuators
Related Products
AD5601 2.7 V to 5.5 V, <100 µA, 8-Bit nanoDACTM D/A Converter, tiny SC70 Package
AD5611 2.7 V to 5.5 V, <100 µA, 10-Bit nanoDACTM D/A Converter, tiny SC70 Package
AD5621 2.7 V to 5.5 V, <100 µA, 12-Bit nanoDACTM D/A Converter, tiny SC70 Package
