Active Receive Mixer From Analog Devices
Analog Devices AD8342
The AD8342 is a highly integrated SiGe active mixer optimized for receiver path down conversion. The input range spans from Low Frequency to 500MHz allowing the part to be used in a broad range of applications including CDMA, GSM Basestation Radios and Private Mobile Radio equipment.
The AD8342 provides a single ended 50% input impedance, on both the RF and LO input ports. An integrated LO driver allows for low LO drive level, typically 0dBm.
The AD8342 can be optimized for power consumption and linearity through an external bias resistor connected to the EXRB pin. The AD8342 is specified for operation of a single +5V supply, consuming only 97mA, and <1mA in power down mode.
The AD8342 is packaged in a space saving 3mm by 3mm 16-lead LFCSP and fully specified over -40° to +85°C temperature range.
