International Rectifier introduces the MTP Switch family of isolated modules insulated with a ceramic aluminum nitride layer for improved junction-to-case thermal resistance. The insulation layer enables as much as seven times better thermal conductivity (cooling capability) than alumina substrates used in competing devices. The new 600V- and 1200V-rated modules combine high-speed IGBTs with optimized diodes to form single-package, space- and assembly-cost saving alternatives to discrete solutions. The new modules are designed for high current industrial power supplies used in high frequency arc welding machines and uninterruptible power supplies (UPS).
Technical Highlights
The 50MT060ULS is a fully-insulated low-side chopper module, made with an International Rectifier Ultrafast IGBT and a HEXFRED® diode with ultrasoft reverse recovery current.
The 50MT060WH is a fully-insulated half-bridge module built with a pair of IR's WARP Speed(tm) IGBTs in parallel and a HEXFRED freewheeling diode with UltraSoft reverse recovery current characteristics. This double-IGBT layout enables efficient power dissipation and current sharing.
Two additional MTP Switch modules are available, with 1200V ratings. The fully-insulated 20MT120UF full-bridge and the 40MT120UH half-bridge modules host 1200V-rated IGBTs. The 1200V devices can be directly connected to the DC bus in the majority of three-phase systems. The half-bridge module is available with on-board temperature monitoring.
Part Number | Package | Voltage VCES | Collector Current | Circuit Configuration |
50MT060ULS | MTP | 600V | 50A @ 122єC | Low side chopper |
50MT060WH | MTP | 600V | 50A @ 109єC | Half bridge |
20MT120UF | MTP | 1200V | 20A @ 106єC | Full bridge |
40MT120UH | MTP | 1200V | 40A @ 105єC | Half bridge |
40MT120UHT | MTP | 1200V | 40A @ 105єC | As above, with thermistor |
Availability and Pricing
Samples are available now. Pricing is as follows:
50MT060ULS: $40 each
50MT060WH: $52 each
20MT120UF, 40MT120UH: $42.00 each
All prices in US dollars and in 1,000-unit quantities.
