RECOM Introduces Compact Size AC/DC Power Converters, 5-60 Watts
RECOM RAC5-DA RAC5-SA RAC5-SB RAC10-SB RAC10-DA RAC10-SA RAC15-TB RAC15-DA RAC15-SA RAC15-SB RAC15-DB RAC15-TA RAC40-SA RAC30-TA RAC40-DA RAC30-0512DA RAC40-TA RAC30-DA RAC30-SA RAC60-SA
RECOM International Power has widened its extensive product portfolio to include for the first time an extensive AC/DC-converter series. The RAC series are PCB-mounting, fully encapsulated AC/DC modules covering the 5W, 10W, 15W and 30W power ranges. Universal inputs allow both 90 - 264 VAC with 47 - 440 Hz or 120 - 370VDC supply voltages. Application engineers can choose between single, dual and triple output models. Available output voltages are 3.3, 5, 12, 15 and 24 Volt for single output converters, ±5, ±12, ±15 and 5/12 volts for dual output models and the output combinations 5/±12 and 5/±15 volts for the triple output versions.
RECOM AC/DC Power Converter RAC05-SB
 The RAC series offer substantial space saving in comparison to standard AC/DC power supplies. The single output 5 watt module is supplied in a fibre-reinforced epoxy housing with dimensions of only 50.8 mm x 25.4 mm x 15.2 mm. The pin compatible 10 Watt module needs only 52.4 mm x 27.2 mm x 23.5 mm of space.
RAC 15
Standard features of this new range are continuous short circuit protection with automatic reset, low output ripple and noise figures, 3000 VAC input-output isolation as well as TÜV -, CE - and UL-certification. Additionally, the RAC converters with 5 W, 10 W and 15 watts power categories are also available in DIN Rail mounting versions with single, dual and triple-outputs via screw terminals, making them ideal for use in electrical cabinets.
