Intersil Achieves 1 nV Noise Performance in a Single-Supply Op Amp
Intersil ISL28190 ISL28290 ISL28191 ISL28291
Intersil Corporation announced the release of the ISL28190, ISL28290, ISL28191 and ISL28291. These devices, part of Intersil’s pinPOINT™ Precision Analog product line, deliver noise performance up to four times better than competitive single-supply op amps. The ISL28X90 sets the new industry standard for single-supply, rail-to-rail output op amps at 1.0 nV/rt(Hz), while the ISL28X91 comes in at just 1.7 nV/rt(Hz).
As the industry’s first ultra-low noise, single-supply op amps, these devices allow designers to simplify designs by achieving noise performance previously only attained with dual supply devices. This, along with the industry’s best harmonic distortion (THD+N) at 0.00017% (ISL28X90) and 0.00018% (ISL28X91) make this family of rail-to-rail output op amps ideally suited for noise-sensitive audio, medical and industrial instrumentation applications.
These op amps are optimized for operation at 5 V and below, with the single channel amplifiers offered in a space-saving SOT23 package while the dual channel amplifiers are offered in a 10-lead MSOP package. Single channel amps in 1.6 mm x 1.6 mm micro-TDFN package and dual channel amps in the 1.8 mm x 1.4 mm micro-TDFN package are now sampling.
The combination of superior noise, harmonic distortion and bandwidth performance is in keeping with Intersil’s complete pinPOINT™ Precision.
Pricing and Availability
The ISL28190 is available in quantities of 1,000 in 6-lead SOT-23 packages starting at $1.58 each. The ISL28290 is available in quantities of 1,000 in 10-lead MSOP packages starting at $2.61 each (tape and reel available). The ISL28191 is available in quantities of 1,000 in 6-lead SOT-23 packages starting at $1.32 each. The ISL28291 is available in quantities of 1,000 in 10-lead MSOP packages starting at $2.38 each (tape and reel available).
