Best-in-Class Active OR'ing MOSFET Controller from Diodes Incorporated Supports Power Supplies up to 400V
Diodes ZXGD3112N7
Diodes Incorporated introduced the ZXGD3112N7. Extending the capability to support redundancy power systems with rail voltages up to ±400 V, this active OR’ing MOSFET controller builds on a successful design employed in previous 40 V and 200 V devices. A low turn-off threshold voltage enables very low RDS(on) MOSFETs to operate as ideal diodes, providing a highly efficient power system that is well-suited for target applications in telecoms systems, data centers and servers, where OR’ing two or more power supplies together provides redundancy.
Diodes - ZXGD3112N7
Recognizing the trend towards using higher system voltages to raise power distribution efficiency, the ZXGD3112N7 also contributes to increased system reliability, since its use in conjunction with low RDS(on) MOSFETs allows operation at lower temperatures compared to the alternative of a Schottky-blocking diode. In addition to increasing system efficiency, its turn off threshold voltage of <5 mV improves light-load stability, while the ability to turn off in <600 ns avoids reverse current flow and prevents a voltage drop on the common rail. A 5 A sink current ensures a fast discharge of the gates of paralleled MOSFETs.
With its best-in-class turn-off threshold voltage and a 400 V rating that is four times that of competitive OR’ing controllers, the ZXGD3112N7 excels in efficiency, reliability and stability over the entire load range.
The ZXGD3112N7 is offered in an SO-7 package.
