Advanced Search +
Main » News » RF
10-23-2007
Intersil's Ultra-small RS-485/RS-422 Single Transmitter Offers Rugged Performance and Best-in-Class Internal ESD Protection
Intersil » ISL3293E, ISL3294E, ISL3295E, ISL3296E, ISL3297E, ISL3298E
Intersil announced the ISL329xE series of 3.3 V-powered RS-485/RS-422 single transmitters designed with excellent +/-16.5 kV ESD protection and ultra-low supply current requirement. These devices come in very small TDFN and SOT23 packages with both package types available in the industrial and extended industrial (-40 C to +125 C) temperature ranges.
Intersil ISL329xE Ultra-small RS-485/RS-422 Single Transmitter
This single transmitter family offers data rate options to match the application speed. For low-speed applications, the family offers slew rate-limited versions at 250 kbps (ISL3293E and ISL3296E), as well as 500 kbps versions (ISL3294E and ISL3297E). The ISL3295E and ISL3298E operate up to 20 Mbps for high-speed applications.
This family of transmitters has low quiescent supply current (Icc = 150 microamps max) that is 1/30th the value of the nearest competitor, making a significant improvement in power critical applications. Additionally, all the devices feature a Tx enable pin that places the IC in a low power shutdown mode (Icc = 1 microamps max) to further reduce power consumption whenever the transmitter is disabled.
The ISL3296E, ISL3297E and ISL3298E are all available in 8-lead TDFN packaging (2 mm x 3 mm) that are 26 % smaller than SOT23 package options (3 mm x 3 mm), saving valuable board space. These versions feature on-board level translators on the enable and data input pins that simplify the design of mixed voltage systems. The logic supply pin (VL) can be connected to a lower voltage processor supply to level shift the input voltages to values compatible with the processor supply. This eliminates the need for external level translators.
The rugged performance of these devices is demonstrated by the high level of ESD protection on the transmitter outputs that are typically exposed to the outside world, as well as the 125 C temperature operating range and enhanced thermal performance of the TDFN package option.
Slices ↓
