Epson Introduces Multilingual Text to Speech Synthesis Chip
Epson S1V30100
Epson announced availability of its multilingual text-to-speech (TTS) synthesis chip for embedded applications. The S1V30100 is a highly integrated companion chip that provides a complete decode path from text input to analog output via headphones or audio line level output signals. The chip can be easily integrated with a wide range of host devices and microcontrollers using a message protocol that runs over either a UART or an SPI link.
The S1V30100 contains Fonix DECtalk(R) v5.0 as its TTS engine, and the chip supports five languages: US English, French, German, Castilian Spanish, and Latin American Spanish. Further languages, such as Japanese, Chinese, and Korean, are currently under development. The chip also supports G.726 ADPCM encoding and decoding for pre-recorded speech at sampling rates of 24, 32, or 40 kbits/s, and has the option to support MP3 and/or AAC decoding of music data if required.
Target applications for the S1V30100 include speech-enabled portable devices, assistive devices for speech or visually impaired users, educational toys, automotive navigation systems, etc. The on-chip A/D and D/A converters can also be accessed directly by the host processor via an I2S interface, thereby allowing general audio data to be input or output to/from the host processor system.
The key features of the S1V30100 are:
  • Multilingual, unconstrained, 5-language TTS (Fonix DECtalk(R)).
  • G.726 ADPCM recording and playback.
  • MP3 and AAC audio decoding.
  • On-chip mono A/D converter and stereo D/A converter (sampling frequencies up to 48 kHz, with 16-bit audio samples).
  • Headphone and line level analogue outputs.
  • UART or SPI Host Interface.
  • 1.8V core operation; 3.3V I/O.
  • 160-pin PFBGA package (10mm x 10mm).
  • Non-volatile storage area for user dictionaries and storage of frequently-used text/data files and/or recorded speech data.
A complete PC-based development/evaluation kit is available.
