International Rectifier Introduced Solution for Synchronous Buck Applications
International Rectifier iP1206
International Rectifier introduced the iP1206, a fully optimized solution for synchronous buck applications including telecom and networking equipment.
The iP1206 is the latest addition to the iPOWIR™ integrated power conversion stage product line, designed for two-phase single output applications up to 30 amps or dual independent outputs up to 15 amps. Both options utilize synchronized 180 degree out-of-phase operation, reducing input current ripple and input voltage ripple. The device is comprised of an optimized power stage and a full function PWM Control IC to achieve high power density.
Features include a switching frequency up to 600 kHz per channel, loss-less current limit, over-voltage and over-temperature protection, pre-bias start up, external synchronization, output voltage tracking and sequencing.
Part Number Package VIN
(min/max)
(V)
VOUT
(V)
IOUT
Max Per Channel
IOUT
Max in 2 Phase Mode
Frequency
iP1206PBF LGA 7.5 V – 14.5 0.8 – 5.5 15 A 30 A Up to 600 kHz
Available design tools include a web-enabled iP1206 Spice circuit simulation and the IRDCiP1206-B, a 15 A per channel, dual output, synchronous buck converter reference design.
Availability and Pricing
Pricing for the iP1206PBF devices begins at $6.89 each in 10,000-unit quantities.
