Advanced Search +
11-30-2017
Analog Devices' Industrial Inertial Measurement Units Improve Navigation and Reliability in Autonomous Machines
Analog Devices » ADIS16470, ADIS16475, ADIS16477, ADIS16465, ADIS16467
Analog Devices, Inc. (ADI) announced a series of five high-performance inertial measurement units (IMUs) that address the navigation- and safety-related needs of industrial applications in several emerging markets, while also reducing their system complexity and cost. The ADIS16470, ADIS16475 and ADIS16477 IMUs deliver exceptional performance improvements in smallest size with standard surface mount assembly. The three different models are optimized to provide a range of performance, cost, and application-suitability needs. The ADIS16465 and ADIS16467 IMUs offer similar performance advantages in a more ruggedized enclosure option. Together, these product advancements bring a previously unavailable performance-for-cost ratio to unmanned aerial vehicle (UAV) applications where designers have previously struggled with costly, risky, and sub-par performance solutions from integrating consumer grade sensors, which also fell short of reliability goals. These new IMUs bring the same benefits to Autonomous Machine applications in fields such as Smart Agriculture where the demands of such rugged equipment previously forced a choice between cost-challenged, highest-grade sensors or performance-limited commercial sensors.
Analog Devices - ADIS16470, ADIS16475, ADIS16477, ADIS16465, ADIS16467
All of the IMUs provide six degree-of-freedom (DoF) sensing via triple-axis MEMS-based accelerometers and gyroscopes, and are focused on the demands of the Industrial "Internet of Moving Things" and its need for precise geolocation. Their performance allows systems to characterize motion accurately despite turbulence, vibration, wind, temperature, and other environmental disturbances, resulting in more-accurate navigation and guidance, and/or instrument stabilization.
Leveraging three decades of experience in inertial sensor design, Analog Devices has engineered an unparalleled combination of reliable high performance, and size/cost effectiveness. With industry leading performance, system designers are now able to rely more heavily on these high-grade sensors versus a previous need to attempt performance boosting via added test, components, calibration, or software aids. The ADIS1646x and ADIS1647x IMUs are specifically designed to reject what are otherwise significant error sources, such as ‘g’-influence, cross-axis sensitivity, and temperature and mechanical stress related drifts.
Key Product Specifications
Product DoF Gyro Range
[°/sec]
Gyro Noise
[°/sec/√Hz rms]
Gyro in-run
Stability
[°/hr]
Accel
Range
[g]
Accel Noise
[μg/√Hz rms]
Accel in-run
Stability
[μg]
Oper Temp Range
[°C]
ADIS16470 6 2000 0.008 8 40 100 13 -25 to 85
ADIS16475/65 6 125/500/2000 0.003 2 8 23 3.6 -40 to 105
ADIS16477/67 6 125/500/2000 0.003 2 40 100 13 -40 to 105
Pricing and Availability
Product Production
Availability
Price Each
per 1,000
Packaging
ADIS16470 Now $149 11×15×11 BGA
ADIS16475/7 Now $365 11×15×11 BGA
ADIS16465/7 End Nov 2017 $385 22×22×9 Module
The new IMUs are supported by the EVAL-ADIS2Z, a PC-based tool for evaluation which enables basic demonstration, individual register access, and high-speed data capture, as well as the breakout boards that simplify connecting ADIS16xxx IMU products to development platforms.
EVAL-ADIS2 Evaluation System
EVAL-ADIS2 Evaluation System.
Slices ↓
