Sick Introduced Transparent Distance Sensor
SICK OD Max Transparent
Sick introduced a new transparent distance sensor - OD Max Transparent.
Transparent Sensor OD MAX
High-end system for maximum close-range accuracy
  • For maximum close-range accuracy demands
  • High-end system: 1 or 2 sensor heads per evaluation unit and the possibility of internal balancing
  • Wide variety of standard interfaces: 4 analogue outputs, 5 switching outputs and 1 RS-232 interface
Data sheet (PDF)
