High Performance 1A LDO.
Intersil ISL80101
The Intersil ISL80101 ia a low-voltage, high-current, single output LDO specified for 1A output current. This part operates from input voltages of 2.2V to 6V and is capable of providing output voltages of 0.8V to 5V on the adjustable VOUT versions. Fixed output voltage options available in 0.8V, 1.2V, 1.5V, 1.8V, 2.5V, 3.3V and 5V. Other custom voltage options available upon request.
For applications that demand in-rush current less than current limit or a longer delay for a valid VOUT, an external capacitor on the soft-start pin provides adjustment. A supply independent ENABLE signal allows the part to be placed into a low quiescent current shutdown mode. Sub-micron CMOS process is utilized for this product family to deliver best in class analog performance and overall value.
This CMOS LDO will consume significantly lower quiescent current as a function of load over bipolar LDOs, which translates into higher efficiency and the ability to consider packages with smaller footprints. Quiescent current is modestly compromised to enable leading class fast load transient response and hence total AC regulation band for an LDO in this category.
Key Features
  • 0.2% initial VOUT Accuracy
  • Designed for 2.2V to 6V Input Supply
  • Dropout Typically 130mV at 1A
  • Fast Load Transient Response
  • Rated Output Current Options of 1A
  • Adjustable In-Rush Current Limiting
  • Fixed and Adjustable VOUT Options Available
  • 58dB Typical PSRR
  • Output Noise of 100μVRMS between 300Hz to 300kHz
  • PG Feature
  • 1V Enable Input Threshold
  • Short-Circuit Current Protection
  • 1A Peak Reverse Current
  • Over-Temperature Shutdown
  • Any Cap Stable with Minimum 10μF Ceramic
  • ±1.8% Guaranteed VOUT Accuracy for Junction Temperature Range from -40°C to +125°C
  • Available in a 10 Ld DFN Package and soon to follow TO220-5, TO263-5 and SOT223-5
  • Pb-Free (RoHS Compliant)
Intersil: ISL80101
Intersil: ISL80101
