Holtek HT56R2x New TinyPower A/D type MCUs
Holtek Semiconductor HT56R22 HT56R23 HT56R24 HT56R25 HT56R26
Holtek is delighted to announce its new 8-bit A/D type TinyPower MCU device range, the HT56R2x series. Using Holtek’s unique TinyPower technology, the special characteristics of this new device series lie in their low power consumption, fast wake-up, multiple clock sources and various operating modes that greatly reduce power requirements to meet the demands of today’s environmentally conscious products. The device range is suitable for application areas such as household appliances, instrumentation, industrial control and exercise equipment etc.
Holtek HT56R2x
The HT56R2x series is composed of five MCU devices encompassing a full range of multiple functions. Among these are a specification which includes a core with an OTP Program Memory capacity of 2K~32K, a RAM Data Memory capacity of 128~2304 bytes and 6~12 stack levels. Regarding peripheral functions, all devices include an 8-channel 12-bit high speed Analog to Digital converter which can measure external environmental signals from sensors such as temperature, humidity etc. An internal 3 to 4-channel 12-bit Pulse Width Modulator function is also included which can be used for motor control operation. As for I/O pins, 22~50 I/O lines are provided which can be used to interface to external switches and other peripheral components. A DAC function is also included, which when used together with the integrated SPI interface, can interface to an external Voice Memory to implement voice functions. Additionally, the inclusion of a dual SPI/I2C serial interface function, an internal Programmable Frequency Divider and a range of two to four 8-bit and 16-bit internal timers, give this new range of devices an exceptionally comprehensive range of features to meet the needs of a huge range of microcontroller based applications.
Holtek also fully supports these devices with its comprehensive hardware and software development tools. Known as the HT-IDE300, these development tools provide features such as real time emulation, memory and register read functions, hardware breakpoints complete with logical setups, full trace facilities etc. All these development tool features combine to ensure that designers have a full suite of tools at hand to provide for rapid and efficient design and debug of their microcontroller based new product applications.
Features
CPU Features
  • Operating voltage:
    • fSYS=32768Hz: 2.2V~5.5V
    • fSYS=4MHz: 2.2V~5.5V
    • fSYS=8MHz: 3.0V~5.5V
    • fSYS=12MHz: 4.5V~5.5V
  • Up to 0.33us instruction cycle with 12MHz system clock at VDD=5V
  • Idle/Sleep mode and wake-up functions to reduce power consumption
  • Oscillator types:
    • External 32768Hz Crystal -- LXT
    • External RC -- ERC
    • Internal 4/8/12MHz RC -- HIRC
    • External high frequency crystal -- HXT
    • Internal 32kHz RC -- LIRC
  • Four operational modes: Normal, Slow, Idle, Sleep
  • Fully integrated internal 4MHz, 8MHz and 12MHz oscillator requires no external components
  • All instructions executed in one or two instruction cycles
  • Table read instructions
  • 63 powerful instructions
  • Up to 12-level subroutine nesting
  • Bit manipulation instruction
Peripheral Features
  • OTP Program Memory: 2Kx14 ~ 32Kx16
  • RAM Data Memory: 128x8 ~ 2304x8 Bits
  • Watchdog Timer function
  • Up to 50 bidirectional I/O lines
  • 8 channel 12-bit ADC
  • Up to 4 channel 12-bit PWM
  • Software controlled 4-SCOM lines LCD driver with 1/2 bias
  • Multiple pin-shared external interrupts
  • Up to three 8-bit programmable Timer/Event Counter with overflow interrupt and prescaler
  • Up to one 16-bit programmable Timer/Event Counter with overflow interrupt
  • Serial Interfaces Module - SIM for SPI or I2C
  • Time-Base functions
  • Low voltage reset function
  • Low voltage detect function
  • PFD/Buzzer for audio frequency generation
  • 12-bit Audio DAC output
  • Wide range of available package types
Selection table
Part No.
Program
Memory
Data
Memory
I/O
Timer
HIRC
(MHz)
RTC
LCD
SCOM
ADC
DAC
PWM
Stack
Package
8-bit
16-bit
HT56R22
2K×14
128×8
22
2
4/8/12 yes 4
12-bit×8
12-bit×1
12-bit × 3
6
16DIP/NSOP/SSOP
20DIPNSOP/SSOP
24SKDIP/SOP/SSOP
HT56R23
4K×15
256×8
42
2
1
12-bit × 4
12
28SKDIP/SOP/SSOP
44QFP
HT56R24
8K×16
640×8
42
2
1
12-bit × 4
12
28SKDIP/SOP/SSOP
44QFP
HT56R25
16K×16
1152×8
50
3
1
12-bit × 4
12
28SKDIP/SOP/SSOP
44/52QFP
HT56R26
32K×16
2304×8
50
3
1
12-bit × 4
12
28SKDIP/SOP/SSOP
44/52QFP
