Differing from the traditional OTP and Mask type technology, Holtek is pleased to announce the release of a new HT83F02 Flash type Voice device. Although OTP technology devices are user programmable, after initial programming no further memory content modifications are possible. As this new HT83F02 device includes Flash type memory, its memory contents can be re-programmed as many times as the user likes. The in-circuit programmable interface also permits device programming even after the device is soldered onto its application PCB. The internal SPI interface can also be used to program the contents of externally connected voice Flash Memories. Voice functions are becoming an increasingly prominent feature in many home appliances, however the requirement to supply voice content in multiple languages can create logistical difficulties for product manufactures. However using Holtek’s new HT83F02 Flash device, the problems of multiple languages and stock management can be easily resolved. Using standard external SPI Flash Memory types, users are free to choose from a range of different memory sizes with flexibility according to different application requirements.
In addition to an internal HOLTEK 8-bit embedded microcontroller, the HT83F02 also includes an integrated Flash Program Memory, high speed SPI and I2C interfaces, a monophonic 12-bit voltage type DAC and a PWM driver which can directly drive 8 or 16 ohm speakers. Requiring very few external components and having high noise immunity and a wide operating temperature of -40°C~+85°C, this new device ensures that users are provided with a range of simple and rapid solutions to their voice product application requirements.
Features
- Operating voltage: 2.4V~5.5V
- System clock: 4MHz~12MHz
- Three oscillators:
- External Crystal - HXT
- External RC - ERC
- Internal RC - HIRC
- Fully integrated internal 4MHz, 8MHz and 12MHz oscillator requires no external components
- Up to 19 I/O pins
- Two sets of Serial Interfaces Module - SIM for SPI or I2C, shared with PB
- 2K×16 Flash Program Memory
- 208×8 Data Memory
- Two 8-bit programmable timer counter with 8-stage prescaler and one time base counter
- 12-bit high quality voltage type D/A output
- PWM circuit direct drive speaker
- Watchdog Timer function
- 8-level subroutine nesting
- 2.7V Low voltage detection, tolerance 5%
- 2.4V Low voltage reset, tolerance 5%
- Power-down function and wake-up feature reduce power consumption
- 63 powerful instructions
- 28-pin SSOP package
The HT83F02 is fully supported with Holtek’s EasyPlay high-level hardware and software development tools. The inclusion of multi mode play features as well as a new generation USB writer (e-Writer Plus), provides designers with a full suite of easy to use highly functional supporting tools for programming both Program Memory and Voice content. These features combine to provide a device with all the integrated features for a wide product application range, in areas such as home security products, anti-theft equipment, healthcare products and household appliances to name but a few. For voice product applications with lower volume and high adaptability requirements, this new device provides an excellent solution for reliable and rapid product development.
