Holtek announce HT68F1x and HT66F1x Flash MCU Device Series
Holtek HT66F13,HT66F14 HT66F15 HT68F13 HT68F14 HT68F15
Holtek is pleased to announce the release of its new Flash series MCUs, in the form of its I/O type HT68F1x series and the A/D type HT66F1x series. All devices meet with full industrial specifications (-40°C~85°C) and have high noise immunity. Together with their In-Circuit Programming capabilities, the devices permit program modifications to be easily implemented with the device still in-circuit, a feature which greatly enhances product flexibility.
Holtek: HT66F1x, HT68F1x Flash MCU
The HT68F1x and HT66F1x series devices also include Holtek’s new multi-function timer modules. These new timer modules are capable of providing functions such as Timer/Counter, Capture, Compare Match Output, Single Pulse Output and PWM signal generation. All devices in the A/D type HT66F1x series also contain a 12-bit high speed ADC and internal voltage reference function.
The new Flash MCU device series includes 1~4K words of Program Memory and 64~192 bytes of SRAM Data Memory. In addition to their crystal and external RC oscillators, all devices also include fully internal RC oscillators, which require no external components and can provide fixed high frequencies of 4MHz, 8MHz, 12MHz and a low frequency of 32KHz. There are also four software COM outputs to drive low count pixel LCD panels.
Features
CPU Features
  • Operating Voltage:
    • fSYS= 8MHz: 2.2V~5.5V
    • fSYS= 12MHz: 2.7V~5.5V
    • fSYS= 20MHz: 4.5V~5.5V
  • Up to 0.2µs instruction cycle with 20MHz system clock at VDD=5V
  • Power down and wake-up functions to reduce power consumption
  • Four oscillators:
    • External Crystal - HXT
    • External RC - ERC
    • Internal RC - HIRC
    • Internal 32kHz RC - LIRC
  • Multi-mode operation: NORMAL, SLOW, IDLE and SLEEP
  • Fully integrated internal 4MHz, 8MHz and 12MHz oscillator requires no external components
  • All instructions executed in one or two instruction cycles
  • Table read instructions
  • 63 powerful instructions
  • Up to 8-level subroutine nesting
  • Bit manipulation instruction
Peripheral Features
  • Flash Program Memory: 1Kx14 ~ 4K×15
  • RAM Data Memory: 64x8 ~ 192×8
  • Watchdog Timer function
  • Up to 26 bidirectional I/O lines
  • Software controlled 4-SCOM lines LCD driver with 1/2 bias
  • Multiple pin-shared external interrupts
  • Multiple Timer Module for time measure, input capture, compare match output, PWM output or single pulse output function
  • Single Time-Base function for generation of fixed time interrupt signal
  • Low voltage reset function
  • Low voltage detect function
  • Wide range of available package types
The series is supplied in a wide range of package types from 16~28 pins. With their exceptional hardware resources and application flexibility, these new Flash MCUs will find excellent use in a wide range of application areas such as household appliances, medical care products, portable devices, battery chargers to name but a few.
To support these new devices, Holtek supplies a full suite of hardware and software tools known as the HT-IDE3000 which includes an In-Circuit-Emulator, full trace analysis functions as well as many other functions to ensure that users have their designs up and running in the shortest time possible.
holtek.com.tw
