Microchip Introduces Low-Cost 8-bit PIC Microcontrollers With XLP Technology and Integrated LCD Control
Microchip PIC16LF1902 PIC16LF1903 PIC16LF1904 PIC16LF1906 PIC16LF1907
MCUs Enable Low-Cost LCD Control With Industry-Leading Low Power
Microchip Technology Inc., a leading provider of microcontroller, analog and Flash-IP solutions, today announced an expansion of its 8-bit segmented LCD microcontroller (MCU) family with five new devices—the PIC16LF1902/3/4/6/7 (PIC16LF190X) MCUs. The PIC16LF190X family supports many general-purpose applications and enables the implementation of LCD into low-power and cost-sensitive designs, such as security tokens, smart cards, medical devices, home appliances, key fobs or any application involving a segmented LCD. Featuring eXtreme Low Power (XLP) technology for sleep currents down to 20 nA, and a typical active current of 35 microamperes per MHz, the MCUs extend battery life, while maintaining accurate timing with a RTC and driving a segmented LCD.
Microchip: PIC16LF190x
Utilizing Microchip’s Enhanced Mid-range architecture, the PIC16LF190X family provides fundamental features and performance without burdening customers with the cost of unused peripherals. These MCUs provide an optimized feature set, including up to 14 KB of Flash program memory, up to 512 Bytes of RAM, up to 14 10-bit Analog-to-Digital Converter (ADC) channels, serial communication, temperature indicator and the capability to drive up to 116 LCD segments. With the addition of XLP technology for extended battery life, and capabilities such as utilizing the integrated temperature indicator to provide crystal-accuracy compensation, low-power RTC support and low voltage-detect support utilizing the internal ADC and voltage reference, the MCUs enable low-cost LCD solutions for a multitude of portable devices.
Features
  • Enhanced Mid-range Core with 49 Instruction, 16 Stack Levels
  • Flash Program Memory with self read/write capability
  • 72 LCD segment drive support
  • Internal 16MHz oscillator
  • 11 Channel 10b ADC with Voltage Reference
  • Integrated Temperature Indicator
  • 25mA Source/Sink current I/O
  • One 8-bit Timers (TMR0)
  • One 16-bit Timer (TMR1)
  • Extended Watchdog Timer (EWDT)
  • Brown-Out Reset (BOR)
  • In Circuit Serial Programming (ICSP)
  • Operating Voltage (1.8V – 3.6V)
  • nanoWatt XLP Technology
“With industry-leading low power and an optimized feature set, the PIC16LF190X family is designed for any low-power segmented LCD or general-purpose application,” said Steve Drehobl, vice president of Microchip’s Security, Microcontroller & Technology Development Division.
PIC16LF1902x Block Diagram
Блок-схема микроконтроллеров PIC16LF190x
Click to enlarge
Development Support
The PIC16LF190X MCUs are supported by the F1 Evaluation Kit (part # DM164132, $69.99) and Platform (part # DM164130-1, $39.99), as well as the PICkit 3 In-Circuit Debugger (part # PG164130, $44.95). Designers can also utilize the full suite of MPLAB development tools, including the MPLAB IDE, MPLAB ICD3, REAL ICE™ In-Circuit Emulator, and HI-TECH C compiler for PIC10/12/16 MCUs.
MCU Packaging, Pricing & Availability
The PIC16LF1902, PIC16LF1903 and PIC16LF1906 MCUs are all available in 28-pin SPDIP, SOIC, SSOP and 4 mm x 4 mm UQFN and die packages. The PIC16LF1904 and PIC16LF1907 MCUs are available in 40-pin PDIP, 5 mm x 5 mm UQFN and die packages, as well as a 44-pin TQFP.
microchip.com
