Maxim announced the 78M6613 IC for simplified implementation of single-phase AC power measurement
Maxim; Teridian 78M6613
Maxim Integrated Products announced the 78M6613 – a highly integrated IC for simplified implementation of single-phase AC power measurement into power supplies, smart appliances, and other applications with embedded AC load monitoring and control. It is packaged in a small, 5mm x 5mm, 32-pin QFN package for optimal space savings.
Teridian/Maxim - 78M6613
At the measurement interface, the device provides four analog inputs for interfacing to voltage and current sensors. Voltages from the sensors are fed to our Single Converter Technology® that uses a 22-bit delta-sigma ADC, independent 32-bit compute engine (CE), digital temperature compensation, and precision voltage references to provide better than 0.5% power measurement accuracy over a wide 2000:1 dynamic range.
The integrated MPU core and 32KB of flash memory provides a flexible means of configuration, post-processing, data formatting, and interfacing to any host processor through the UART interface and/or DIO pins. Complete application firmware is available from Maxim and can be preloaded into the IC during manufacturing test. Alternatively, a complete array of ICE, development tools, and programming libraries are available to allow customization for each application.
An evaluation kit is available: 78M6613-PSU-1 78M6613-EVM-1
Key Features
  • < 0.5% Wh Accuracy Over Wide 2000:1 Current Range and Over Temperature
  • Voltage Reference < 40ppm/°C
  • Four Sensor Inputs—V3P3A Referenced
  • 22-Bit Delta-Sigma ADC with Independent 32-Bit Compute Engine (CE)
  • 8-Bit MPU (80515), One Clock Cycle per Instruction with 2KB MPU XRAM
  • 32KB Flash with Security
  • Integrated In-Circuit Emulator (ICE) Interface for MPU Debug
  • 32kHz Time Base with Hardware Watchdog Timer
  • UART Interface and Up to 10 General-Purpose 5V Tolerant I/O Pins
  • Packaged in a RoHS-Compliant (6/6) Lead(Pb)-Free, 32-Pin QFN (5mm x5mm)
  • Complete Application Firmware Provides:
    • True RMS Calculations for Current, Voltage, Line Frequency, Real Power, Reactive Power, Apparent Power, and Power Factor
    • Accumulated Watt-Hours, Kilowatt-Hours
    • Intelligent Switch Control at Zero Crossings
    • Digital Temperature Compensation
    • Phase Compensation (±15°)
    • Quick Calibration Routines
    • 46-64Hz Line Frequency Range with Same Calibration
Applications/Uses
  • Building Automation
  • Consumer Appliances
  • Data Center, Telecom, and Storage Power Supplies
  • Home Automation
  • Indoor/Outdoor Lighting
maxim-ic.com
