TI's new UCC28220 and UCC28221 peak current-mode controllers use advanced interleaving techniques to control two isolated power stages to maximize power density, reduce output current ripple and improve transient response. The devices, available in either interleaved forward or interleaved fly-back isolated topologies, integrate two PWM channels operating at 180 degrees out of phase to control one high current output. In addition, the controllers provide programmable internal slope compensation with an internal circuit to precisely match currents between the two channels.
Key Features of UCC28220 and UCC28221:
- Up to 2 MHz Programmable Oscillator with Up to 1-MHz Operation per Channel'
- Matched Internal Slope Compensation'
- Programmable Maximum Duty Cycle Clamp with 60 to 90 Percent per Channel'
- Accurate Line Under and Over-Voltage Sense with Programmable Hysteresis'
- 110-V Internal Start-Up JFET in the UCC28221'
- Programmable Soft Start'
- Opto-Coupler Interface'
- Current Sense Discharge Transistor for Improved Noise Immunity'
- Operating Temperature Range of -40°C to 105°C
Availability, Packaging and Pricing
The UCC28220 and UCC28221 are available in volume from TI and its authorized distributors. The UCC28220 is available in both 16-pin SOIC package and low-profile TSSOP packages. The UCC28221 with the high voltage startup circuit comes in a 16-pin SOIC and a slightly larger 20-pin TSSOP package to allow for higher voltage pin spacing that meets UL1950 "creepage clearance" safety requirements. Suggested resale pricing is $1.49 and $1.57 in quantities of 1,000 units for UCC28220 and UCC28221 respectively. Half-brick evaluation modules that include a 200-W 48-V to 12-V converter are available in less than 24 hours through'power.ti.com.'
