News & Press Releases Linear Technology - 2
Manufacturer: "Linear Technology"
Search results: 93 Output: 11-20
  1. Linear Technology announces the LT6658 , a precision voltage reference that incorporates two high current output buffers. Based on a 2.5 V bandgap voltage reference, each output can be separately configured for any voltage between 2.5 V and 6 V. ...
    05-11-2016
  2. Linear Technology Corporation introduces the LTM4643 quad output step-down uModule® (power module) regulator, configurable as a single output (12 A), dual (6 A 6 A or 9 A 3 A), or quad (3 A each) regulator in a 9 mm × 15 mm × 1.82 ...
    05-11-2016
  1. Linear Technology Corporation announces the LT3045 , an ultralow noise, ultrahigh power supply ripple rejection (PSRR) low dropout voltage linear regulator, a higher output current version of the widely accepted 200 mA LT3042 ultralow noise LDO. ...
    19-10-2016
  2. Linear Technology introduces the LTC5596 , a high frequency, wideband and high dynamic range RMS power detector that provides accurate, true power measurement of RF and microwave signals independent of modulation and waveforms. The LTC5596 responds ...
    06-10-2016
  3. Linear Technology Corporation introduces the LTC2947 power and energy monitor for 0 V to 15 V DC supply rails. Most power and energy monitoring ICs use an external sense resistor to measure current. However, choosing a sense resistor is not an easy ...
    20-09-2016
  4. Linear Technology introduces the LTC2986 high performance digital temperature measurement IC, which directly digitizes any combination of thermocouples, RTDs, thermistors and external diodes with 0.1 C conformity and 0.001 C resolution. The LTC2986 ...
    13-09-2016
  5. Linear Technology Corporation announces the LTC3256 , a highly integrated, high voltage low noise dual output power supply, which takes a single positive input and generates 5 V and 3.3 V step-down supplies with high efficiency and no inductors. ...
    24-08-2016
  6. Linear Technology announces the LTC3374A , a highly integrated general-purpose power management solution for systems requiring multiple low voltage power supplies. The device can be configured to provide 2 to 8 independent regulated outputs with 15 ...
    23-08-2016
  7. Linear Technology Corporation introduces the LTC2508-32 , an ultrahigh precision 32-bit successive approximation register (SAR) analog-to-digital converter (ADC). Many high performance applications, including data acquisition, industrial control ...
    16-08-2016
  8. Linear Technology introduces the LTM8053 , a uModule® (power module) step-down regulator with up to 40 V input voltage (42 V abs max), which can safely operate from unregulated or fluctuating 12 V to 36 V input supplies in noisy environments, ...
    22-06-2016
Sort by: relevance / date
