News & Press Releases Linear Technology - 4
Manufacturer: "Linear Technology"
Search results: 93 Output: 31-40
  1. Linear Technology Corporation announces the LT3091 , the latest addition to our LDO+ family, a 1.5 A low dropout negative linear regulator featuring low noise, rail-to-rail operation, precision programmable current limit and a bidirectional output ...
    04-12-2015
  2. Linear Technology Corporation introduces the LTC2380-24 , a breakthrough no latency 24-bit 2 Msps successive approximation register (SAR) analog-to-digital converter (ADC). The LTC2380-24 features an integrated digital filter that averages 1 to ...
    10-11-2015
  1. Linear Technology Corporation introduces the LTC4282 , an energy monitoring Hot Swap controller with dual MOSFET drive to enable 100 A and higher current board designs. The LTC4282 ensures safe board insertion and removal from live 2.9 V to 33 V ...
    09-10-2015
  2. Linear Technology announces the LTC3265 , a high voltage, highly integrated, low noise dual output power supply which takes a single positive input supply (V IN_P ) and generates low noise bipolar rails up to 2•V IN_P without any inductors. ...
    14-09-2015
  3. Linear Technology announces the LTC5549, a double-balanced mixer that can operate either as an upconverter or downconverter, with a very wide RF frequency range from 2 GHz to 14 GHz. The LTC5549 offers exceptionally high linearity of 24.4 dBm IIP3 ...
    13-08-2015
  4. Linear Technology Corporation announces the LT8494, a current mode, fixed frequency SEPIC/boost DC/DC converter with an internal 2 A, 70 V switch. Ultralow quiescent current of only 7 uA makes the device ideal for always-on automotive or other ...
    23-07-2015
  5. Linear Technology Corporation introduces the LTC2984, a high performance digital temperature measurement IC that directly digitizes RTDs, thermocouples, thermistors and external diodes with 0.1 C conformity and 0.001 C resolution. The LTC2984 ...
    08-07-2015
  6. The LT3952 is a current mode step-up DC/DC converter with an internal 60 V, 4 A DMOS power switch. It is specifically designed by Linear Technology to drive high power LEDs in multiple configurations. It combines input and output current regulation ...
    21-05-2015
  7. Wireless CAD & Software Linear Technology SmartMesh IP LTC5800-IPM LTP5901/2-IPM
    Linear Technology ’s SmartMesh IP ™ wireless sensor networking products now provide the ability to program industrial Internet of Things (IoT) applications directly on the embedded ARM Cortex M3, running Micrium’s uC/OSII ...
    24-03-2015
  8. Linear Technology Corporation announces the LTC6752 family of comparators with fast rise and fall times of 1.2 ns and a toggle frequency of 280 MHz, making them the fastest CMOS output comparators available today. Designed for driving logic levels ...
    24-03-2015
Sort by: relevance / date
