News & Press Releases Linear Technology - 6
Manufacturer: "Linear Technology"
Search results: 93 Output: 51-60
  1. Linear Technology Corporation introduces the LTM4634 , a triple output step-down uModule® (micromodule) regulator in a 15 mm × 15 mm × 5.01 mm BGA package with integrated heat sink. The thermally efficient package enables the ...
    28-08-2014
  2. Amplifiers Linear Technology LTC6090 LTC6090-5 LTC6091
    Linear Technology announces the LTC6091 and LTC6090-5 , additions to the LTC6090 family of precision operational amplifiers which operate on a supply voltage up to 140 V ( 70 V). The dual LTC6091 features separate output disable pins, making it ...
    07-08-2014
  1. The LT3669 is an IO-Link PHY compatible (COM1/COM2/COM3) industrial transceiver that includes a high efficiency step-down regulator and a low dropout linear regulator. The device offers cable interface protection to 60 V. Wake-up detect ...
    17-07-2014
  2. Linear Technology Corporation announces the LT3063 , a high voltage, low noise, low dropout voltage linear regulator with active output discharge. The IC delivers up to 200 mA of continuous output current with a 300 mV dropout voltage at full load. ...
    14-07-2014
  3. Linear Technology Corporation introduces the LTC2338-18 , an 18-bit 1 Msps no latency analog-to-digital converter (ADC) with a wide 10.24 V fully differential, true bipolar input range for high voltage, industrial applications. The device operates ...
    31-01-2014
  4. Linear Technology Corporation introduces the LTC3875 , a dual output curren tmode synchronous step-down DC/DC controller that enables the use of very low DC resistance (DCR) power inductors by using a novel DCR sensing architecture that enhances ...
    23-01-2014
  5. Supply Power Linear Technology LT8610A LT8610AB
    Linear Technology Corporation announces the LT8610A and LT8610AB . Both are 3.5 A, 42 V input capable synchronous step-down switching regulators. Synchronous rectification delivers efficiency as high as 96% while Burst Mode operation keeps ...
    18-12-2013
  6. Linear Technology Corporation announces the LT8490 , a synchronous buck-boost battery charging controller for lead acid and Lithium batteries, featuring automatic maximum power point tracking (MPPT) and temperature compensation. The device operates ...
    03-12-2013
  7. Linear Technology Corporation announces the LT8614 , a 4A, 42V input capable synchronous step-down switching regulator. A unique Silent Switcher™ architecture reduces EMI/EMC emissions by more than 20dB, well below the CISPR 25 Class 5 limit. ...
    29-10-2013
  8. Amplifiers Linear Technology LTC2057 LTC2057HV
    Linear Technology introduces the LTC2057HV , a zero-drift amplifier featuring self­calibrating circuitry that provides high DC precision and stability over changes in temperature, time, input range and supply voltage. With 5µV input ...
    02-10-2013
Sort by: relevance / date
