News & Press Releases Linear Technology - 8
Manufacturer: "Linear Technology"
Search results: 93 Output: 71-80
  1. Linear Technology Corporation introduces the LT4275 , LTPoE++™, PoE+ and PoE-compliant powered device (PD) interface controllers for applications requiring up to 90W of delivered power. PoE+ limits the maximum PD power delivery to 25.5W, ...
    04-09-2012
  2. Linear Technology Corporation announces the LT8300 , a low quiescent current monolithic flyback regulator that significantly simplifies the design of an isolated DC/DC converter. No optocoupler, third winding or signal transformer are required for ...
    30-08-2012
  1. Linear Technology introduces the LTM8029 , a 5µA quiescent current DC/DC step-down µModule® regulator with very low dropout voltage and a wide input and output voltage range of operation. Capable of delivering up to 600mA, the ...
    17-05-2012
  2. Linear Technology Corporation introduces the LTC3613 , a high frequency controlled on-time synchronous step-down DC/DC converter with differential output voltage sensing and clock synchronization. The controlled on-time, valley current mode ...
    16-01-2012
  3. Linear Technology introduces the LTC2991 , an 8-channel I²C temperature, voltage and current monitor for 3V and 5V systems. The LTC2991 is a highly integrated monitoring solution that incorporates a 14-bit ADC, 10ppm/ C voltage reference and ...
    07-09-2011
  4. Linear Technology Corporation announces the LT3641 , a dual channel, current mode step-down switching regulator with a power-on reset and watchdog timer. Its 4V to 42V input voltage range with 55V transient capability makes it ideal for load dump ...
    30-08-2011
  5. Linear Technology announced the LT8500 , a pulse width modulation (PWM) generator with 48 independent channels. Each channel has an individually adjustable 12-bit (4,096 steps) PWM register and a 6-bit (64 step) 50% correction register. All ...
    15-08-2011
  6. Linear Technology announced a new high reliability MP-grade version of the LT1431 , a three-terminal adjustable shunt voltage regulator that operates over a -55 C to 150 C junction temperature range. This device has a 100mA sink capability, 0.4% ...
    08-08-2011
  7. Linear Technology announces the LT6109 , a complete high side current sense device that incorporates a current sense amplifier, dual comparators and a precision 400mV voltage reference. When connected to a current shunt resistor, the high side ...
    18-07-2011
  8. Linear Technology has announced the LTC6803 , a second generation high voltage battery monitor for hybrid/electric vehicle (HEVs), electric vehicles (EVs) and other high voltage, high performance battery systems. The LTC6803 is a complete battery ...
    18-07-2011
Sort by: relevance / date
