Renesas Electronics: SH7734 - SuperH Microcontroller Supporting High-Resolution Displays and Gigabit Ethernet
Renesas SH7734
Renesas: SH7734 - SuperH Microcontroller Supporting High-Resolution Displays and Gigabit Ethernet
Renesas Electronics and its subsidiary, Renesas Mobile Corporation announced the availability of its new 32-bit microcontroller (MCU), the SH7734
The SH7734 has a CPU core with a maximum operating frequency of 533 MHz and on-chip 4-way set-associative cache memory with 32 kilobytes each for instruction and data.
The SH7734 is equipped with a built-in graphics accelerator function that conforms to the OpenVG 1.1 specification. As a display controller, it has a built-in display unit that supports RGB888 digital output. A built-in Gigabit Ethernet controller enables high-speed data transfer over a network. Furthermore, the built-in controller used for main memory supports both DDR2 and DDR3-SDRAM.
Other on-chip peripheral functions include USB 2.0 host/function, a DMA controller, serial interface, NAND flash interface, timers, serial sound interface, SD host interface, and multimedia card interface.
Key Features:
  • 2D graphics accelerator supporting OpenVG1.1 API [option]
  • The Display Unit(DU) supports a RGB888(24bit full-color) output.
  • Built-in Gigabit Ethernet MAC
  • DDR2/DDR3-SDRAM controller
  • SH-4A superscalar CPU core with operating up to 533MHz
  • Built-in USB2.0 High speed Host/Function controller
  • Other optional functions
    • SD host interface [option]
    • Stream interface [option]
    • RCAN interface [option]
SH7734 Product Specifications
  • CPU core
    • SH-4A core
    • Max. operating frequency : 533MHz
    • Cache memory
      • Instruction cache (IC) : 32 KB, 4-way set associative
      • Operand cache (OC) : 32 KB, 4-way set associative
    • On-chip RAM
      • ILRAM: 16KB (High speed access at instruction fetch )
      • OLRAM: 16KB (High speed access during data access )
    • FPU, MMU
  • External interfaces
    • EX_Bus interface
      • Supports connection to SRAM, burst ROM, ATA etc.
      • Bus width : 8/16bit selectable
      • max.44.4MHz(CPU:533MHz)
      • max.50MHz(CPU:400MHz)
    • DDR2/DDR3-SDRAM memory controller
      • Bus width : 16bit
      • Maximum operating frequency : 300MHz
      • Burst length :
        • DDR2-SDRAM : 8 or 4
        • DDR3-SDRAM : 8
  • Display controller
    • Display Unit
    • Display size
      • (ex1)WVGA(832×496, 32bit/pixel) : 1 Plane
      • (ex2)XGA(1024×768, 16bit/pixel data) : 1 Plane
      • (ex3)WXGA(1280×768) : 1 Plane
    • Display Unit can blend max 8 planes that alpha planes are included.
    • Digital RGB output : RGB888 output
  • Gigabit Ethernet controller
  • USB2.0
    • USB 2.0 interface
    • Ports: 2 (1 host/function port, 1 host port)
    • Host: Support for EHCI ver. 1.0 and OHCI ver. 1.0a
    • Function: On-chip device controller with USB 2.0 support
    • Transfer speed: High-speed/full-speed
  • On-chip peripheral modules
    • Vin function ( BT656)
    • Serial sound interface (SSI) (max 4ch)
    • Sampling rate convertor (SRC)
    • Timer Unit (TMU) (9ch)
    • Multi function timer(MTU2)
    • I2C bus interface (max 2ch)
    • Serial peripheral interface (SPI) (max 2ch)
    • SCI with 16 FIFO (SCIF) (max 5ch)
    • SCI with 128 FIFO (HSCIF) (max 1ch)
    • Host interface (HIF) (max 1ch)
    • NAND Flash I/F (max 1ch)
    • A/D converter (10bit) (max 8ch)
    • WDT
    • RTC
    • DMAC(34ch)
    • MMC interface(max 1ch)
  • Other optional modules
    • Stream Interface(max 2ch) [option]
    • RCAN (max 2ch) [option]
    • SDHI(max 3ch) [option]
    • OpenVG1.1 2D graphics accelerator [option]
  • User Debugging Interface (H-UDI)
    • Supports connection to emulator
    • AUD support: dedicated emulator function
  • Package
    • 440 pin BGA(21mm × 21mm, 0.8mm pitch)
Key Applications:
  • Equipments with a LCD display, FA, Network equipment, Porable display equipment
renesas.eu
