Differential amp has 6 dB lower noise, twice the bandwidth
Roy McCammon
EDN
The traditional three op-amp differential amplifier's signal to noise ratio can be improved by 6 dB by adding a resistor and slightly changing the connections. There is a trade-off though: The traditional topology has a high input impedance, whereas the low-noise version has a lower input impedance.
Figure 1.
Figure 1 depicts a traditional three op-amp differential amplifier. For the sake of simplicity we will assume that A3 is an ideal noiseless opamp and the four resistors labeled R6 are exactly equal, so that the output of A3 is given exactly by V1 – V2. The A3 circuit is a perfect subtractor. We will also assume that the two resistors labeled R1 are exactly equal. The outputs are given by:
 where:
Vn1 = voltage noise from opamp A1, RMS value = Vn,
Vn2 = voltage noise from opamp A2, RMS value = Vn.
If R1 = 20 kΩ and R3 = 1 kΩ, then:
Vout = 41Vs + 41Vn1 + 41Vn2.
Vn1 and Vn2 are random, so that the polarity can be chosen for convenience. The signal and the noise sources all have the same gain, so the signal to noise power ratio is
Figure 2.
Figure 2 depicts the circuit of this Design Idea. Resistor R3 has been duplicated and its hookup modified. The outputs of this circuit are given by:
where:
If R1 = 20kΩ, and R3a = R3b = R3 = 1kΩ then:
Vout = 41Vs + 21Vn1 + 21Vn2
The output signal to noise power ratio is
which is almost equal to
That is about 6 dB better than the traditional circuit. What is going on?
The answer is revealed by looking at the outputs of A1 and A2 in the traditional circuit. The output of A1 has a noise component due to its own noise, and an almost equal component due to the noise from A2, which also has noise components from both op-amps. In the new circuit, the output of each opamp has noise only from its own internal noise source.
The connection between A1 and A2 is through R3. A1’s internal voltage noise source, Vn1, drives its internal non-inverting input, Vp1, which causes the output of A1 to have a noise component from its own noise source. Normal negative feedback action causes A1’s summing junction to follow its non-inverting input, meaning A1’s internal noise will appear on its summing junction, Vj1, which will drive a noise current into R3 that will be injected into the summing junction of A2. In this way, the noise source in A1 appears at the output of both A1 and A2. Likewise the noise source in A2 appears in the output of both A1 and A2.
The new circuit works the same way except that the noise at the summing junction drives R3a, which connects back to the low impedance source instead of the summing junction of the other amplifier.
The new circuit also has about twice the bandwidth of the traditional circuit. In the traditional circuit, some of the drive for A1 comes from A2 and some of the drive for A2 comes from A1. When the input frequency reaches the point where A1 and A2 begin to roll off, they also begin to see less drive from the other amplifier. In the new circuit, the drive comes exclusively from the input source. The net effect is that the traditional amplifier reaches its 3 dB frequency about an octave lower than the new circuit.
Compared to the traditional circuit, the new circuit has all the advantages, including the same common mode rejection, less noise, and more bandwidth, but has one drawback: the input impedance is R3, which in this case would be 1 kΩ. That would be adequate if the source was, for example, a balanced twisted pair transmission line (typically 100 Ω).
EDN
