Freescale: MC13260 System-on-Chip (SoC) Two-Way Radio
Freescale MC13260
Single chip integrates an ARM processor, software defined modem and RF transceiver; supports the growing number of digital protocols
The MC13260 System-on-Chip (SoC) Two-Way Radio is a single-chip integrated microcontroller, software-defined modem, and RF transceiver intended for use in the two-way radio market. The MC13260 SoC Two-Way Radio incorporates a 32-bit ARM9 microcontroller, a highly optimized software-defined vector modem processor, a high-performance sub-1GHz transceiver achieving higher frequencies with external components, and mixed-signal analog circuits for voice and peripheral support. The overall design and programmability of MC13260 enables rapid time to market for multi-mode products, such as dual-mode analog/digital radios.
Freescale: MC13260
The high level of integration provides support for a comprehensive radio platform in a single package without the requirement of an additional external processor. This results in a small board area and a cost-effective solution. The MC13260 SoC Two-Way Radio provides a wide range of wireless communication protocol options, supporting both analog and digital modulation schemes.
The ARM926EJ-S provides flexibility and sufficient computational performance to execute a variety of speech and audio CODECs for use in digital voice communication, alerts, or music playback. The software-defined modem is a highly optimized vector digital signal processor enabling the implementation of analog and digital protocols, as well as enabling simple upgrade capabilities through software as standards evolve.
A complete two-way radio can be built using the MC13260 System-on-Chip Two-Way Radio as shown in Figure below.
Click to enlarge
The MC13260 SoC Two-Way Radio provides the following device level features:
  • ARM9 Platform
    • ARM926EJ-S core supporting clock speed up to 150 MHz.
    • EmbeddedICE logic.
    • Five-stage pipeline for ARM/Thumb.
    • Five-stage pipeline for Java.
    • External co-processor interface.
    • MMU, instruction and data caches.
    • Caches are virtually indexed and virtually addressed.
    • Supports ARM, Thumb, and Java.
    • Supports a JTAG port compliant to the ARM Debug Architecture.
  • Modem Engine
    • Programmable architecture; flexibility to implement a variety of functionality using the same hardware.
    • Supports both real and complex modes of operation.
    • 52-bit fixed length VLIW instruction format.
    • Employs SIMD Architecture.
    • Nine-stage pipeline for instruction and data processing.
    • Uses 16-bit floating-point number representation thus offering a wide dynamic range.
    • Single clock cycle execution typical for modem macro-instruction.
    • DMEM which supports a 128-bit data read/write in each cycle.
    • Register bank of eight registers, each 128-bits wide.
    • The register bank supports 6 reads and up to 3 writes per cycle.
    • Two Arithmetic Units (AU), each unit is:
      • Capable of producing one complex multiply-and-add result, or
      • Four real multiply-and-add results in one clock cycle.
    • Produces one Decimation in Frequency (DIF) FFT or Decimation in Time (DIT) FFT butterfly per cycle.
    • Supports four levels of nested hardware loops.
    • Supports 8-deep Return Address Stack for subroutine calls.
    • Special Arithmetic Unit (SAU) to perform several common special arithmetic operations for example, 1/x, 1/sqrt(x),1/(1+exp(|x|)), log(x) and so on, by using look-up tables.
    • Comparator unit capable of minima/maxima search.
    • Conversion from fixed-point representation to floating-point representation and vice versa on-the-fly.
    • Supports conditional and unconditional program jumps and subroutine calls.
    • General Purpose Unit (GPU) capable of some logical and arithmetic operations, for example, logical AND, OR, NOT, EXOR and so on, besides arithmetic/logical shift operations.
  • Transceiver
    • Contains receive, transmit, and frequency generation subsystems.
    • Contains high fidelity converters for sub-MHz signals.
    • Capable of an RF frequency range of 60 MHz–960 MHz with a frequency resolution of 1 Hz or less.
    • High performance synthesizer achieves 75 dB adjacent channel selectivity.
    • Provides configurable RF data channel bandwidth from 6.25 kHz–600 kHz.
    • Contains one general purpose A/D and three general purpose D/A converters.
    • Supports an extended operating frequency range up to 3 GHz with external circuitry.
    • Supports linear transmit using an external modulator.
    • Voice CODEC
  • Digital Peripherals
    • Advanced Security Module (ASM)
    • Clock Monitor (CLKMON)
    • Clock Control Module (CCM)
      • Provides a mechanism to switch from one clock source to another without any glitch generation
      • Two clock sources comprise a high speed clock, CKIH, and low speed clock, CKIL.
      • Implements integral clock dividers
      • Manages various low-power modes defined for the SoC.
    • Configurable Serial Peripheral Interface (CSPI)
    • Deep Sleep Module (DSM)
    • Enhanced Periodic Interrupt Timer (EPIT)
      • 32-bit down counter with clock source selection.
      • 12-bit prescaler for division of input clock frequency.
      • Counter value can be programmed on the fly.
      • Can be programmed to be active in low-power and debug modes.
      • Interrupt generation when counter reaches the Compare value.
    • General Purpose Input/Output (GPIO)
      • General purpose input/output logic:
        • Ability to drive a specific data to the pad using DR register.
        • Ability to control the direction of the pad using the GDIR register.
        • The core is able to sample the status of the corresponding pads by reading the PSR register.
      • GPIO interrupts support:
        • Up to 32 interrupts.
        • Ability to identify interrupt edges.
        • Generate three one-bit interrupt lines to the SoC interrupt controller.
    • General Purpose Analog-to-Digital Converter (GPADC)
    • General Purpose Timer (GPT)
      • One 32-bit up-counter with clock source selection, including external clock.
      • Two input capture channels with programmable trigger edge.
      • Three output compare channels with programmable output mode.
        • Supports forced compare feature.
      • Interrupt generation at capture, compare, rollover events.
      • Restart or free-run modes for counter operation.
    • High-Performance Direct Memory Access (HDMA)
    • Inter-Integrated Circuit (I2C)
    • IC Identification Module (IIM)
      • Provides interface to the fusebanks, allowing fuses to be read or programmed.
      • Fuses may be programmed by software, directly by JTAG, or indirectly by JTAG via a processor.
      • Ability to override fuse values in software (does not affect the fuse element); override capability can be permanently disabled.
      • Ability to write-protect e-Fuses.
      • Ability to scan-protect (read and program).
    • KeyPad Port (KPP)
      • Supports a key pad matrix of up to 5 rows × 4 columns.
      • Port pins can be used as general purpose I/O.
      • Open drain design.
      • Glitch suppression circuit design.
      • Multiple keys detection.
      • Long key press detection.
      • Standby key press detection.
      • Synchronizer chain clear.
      • Double-edge interrupts to enable multiple keys detect or N-key rollover.
    • Pulse-Width Modulator (PWM)
      • Two selectable input clock sources.
      • 16-bit resolution.
      • Two stage input clock divider (2, 4, 8, 16-divider and 7-bit prescaler).
      • Programmable through four user-accessible 32-bit registers.
      • 4 × 16 bit FIFO with associated status and interrupts.
      • Software Reset function available to reset the entire PWM subsystem.
    • Random Number Generator (RNGB)
    • Real Time Clock (RTC)
    • System Reset Control (SRC)
      • Controls the Reset of the SoC.
      • Controls the operation of CLKMONs and the power management functions.
    • Synchronous Serial Interface (SSI)
    • Smart LCD Controller (SLCDC)
      • Transfers data from the display memory buffer to the external display device.
        • Direct Memory Access (DMA) transfers the data transparently with minimal software intervention.
        • Bus utilization of the DMA is controllable and deterministic.
      • Reduce the CPU’s involvement in the transfer of data from memory to the display device.
      • Transfers are optimized by using Direct Memory Access (DMA).
      • After transfer is complete, a maskable interrupt is generated indicating the status.
      • Supports Serial and parallel interfaces.
      • Supports only writes to the display controller. Read operations from the display controller are not supported.
      • Two 32 × 8-bit FIFOs.
      • Control and status registers are accessible via the IP bus.
      • Configurable to write image data to an external LCD controller via a 4-line serial, 3-line serial, an 8-bit parallel interface.
    • Timer Module (TMR)
      • Four 16-bit counters/timers.
      • Counts up/down.
      • Counters are cascadable.
      • Supports programmable modulo count.
      • Maximum count rate equals peripheral clock/2 for external clocks.
      • Maximum count rate equals peripheral clock for internal clocks.
      • Count once or repeatedly.
      • Counters are pre-loadable.
      • Compare Registers are pre-loadable.
      • Counters can share available input pins.
      • Separate prescaler for each counter.
      • Each counter has capture and compare capability.
      • Timer Count Increment/Decrement Disable via DIS_L1T Input.
    • Universal Asynchronous Receiver/Transmitter (UART1, UART2)
    • USB Full Speed Device Controller (USB-FS)
      • USB 2.0 compliant Full Speed device controller.
      • Eight bidirectional End Points.
      • Support control, isochronous, bulk and interrupt End Point types.
      • DMA or FIFO data stream interface.
      • Low-power suspend mode.
    • USB Transceiver
      • Complies with Universal Serial Bus Specification, Revision 2.0.
      • Runs at low (1.5 Mbps) and full (12 Mbps) speeds.
      • Converts USB differential voltages to a digital logic signal and vice versa.
      • Supports a 3.5 meter maximum cable length connected to the USB data bus.
    • Watchdog Timer (WDOG)
    • RF/Analog Interfacing Peripherals
    • General Purpose Analog-to-Digital Converter Interface (GPADC-IF)
      • IP bus interface for ARM.
      • Interrupt generation.
      • Generation of control signals to the analog GPADC circuit.
      • Schedules data conversions on the multiplexed A/D inputs.
      • GPADC can be triggered by software or Transceiver Sequence Manager.
    • RF Data Interface (RFDI)
      • Provides bus interface for Rx and Tx data.
      • Contains a multistage decimation filter to convert slow data rate to fast date rate.
      • Contains a multi-stage interpolation filter to convert fast date rate to slow date rate.
      • Rx FIFO to provide temporary data storage on receiving data path.
      • SYNTH FIFO to provide temporary data storage on frequency synthesis data path.
      • Operations to be controlled by TSM.
      • Supports TxIQ mode allowing the RFDI block to provide the I and Q data to the high speed DACs.
    • Transceiver Sequence Manager (TSM)
      • Up to 32 sequence events for either:
        • Separated Rx/Tx warm-up/warm-down events, or
        • Combined warm-up / warm-down events.
      • Triggered by pre-selected timer from TMR module (Timer Module).
      • Programmable selection between Receive or Transmit Sequence.
      • Supports autonomous execution of an already-started sequence without host core intervention.
      • Start sequences either synchronized with TMR timer, or initiated by setting a start signal.
      • Directly or indirectly (delayed from a signal being set) initiated warmdown sequence.
      • Three maskable interrupt signals are generated to the ARM9 core at the end of sequences.
      • Allow software overriding of its outputs.
    • Transmit Power Ramp Control (TPRC1, TPRC2, TPRC3)
      • TSM controls ramp direction and ramp trigger.
      • MCU programs the ramp profile into LUT for each PA stage. Loaded before ramp trigger.
      • MCU programs target power for each PA stage. Loaded before ramp trigger.
      • MCU programs duration and ramp step which determines the number of L1 clocks in between samples.
      • Each TPRC controls one of the three DACs
      • Enables DAC selection to determine whether one, two, or three DACs are enabled during ramping.
      • MCU controls ramp bypass to apply static target power value to input of DAC.
      • Supports a bypass mode to allow direct streaming of I and Q data from RFDI to the GPDACs.
MC13260 SoC block Diagram
Click to enlarge
freescale.com
electronicdesign.com
