Tiny Audio Amplifier Using LM386
LM386
Specifications
The Tiny Audio Amplifier kit is a good choice for battery operation. It is based on LM386 IC.
  • Power supply - 6 - 12 VDC
  • Output power - 1 W, 8 Ohm
  • The quiescent power drain is only 24 mW when operating from 6 VDC
  • Self-centering output quiescent voltage
  • Onboard PRESET to adjust volume
  • Terminal pins for connecting power supply, audio signal and speaker
  • Power-On LED indicator
  • ON/OFF PCB mounted slide switch for power supply
  • Four mounting holes of 3.2 mm each
  • PCB dimensions 44 mm x 44 mm
Schematic
Schematic Tiny Audio Amplifier Using LM386
Parts List
Parts List
Inputs - Outputs configuration
PCB Tiny Audio Amplifier Using LM386
Download this circuit in PDF
electronics-lab.com
