Battery-powered Night Lamp
Ultra-low current drawing 1.5V battery supply
Circuit diagram:
Parts:
R1, R2
1M   1/4W Resistors
R3
47K   1/4W Resistor (optional: see Notes)
R4
Photo resistor (any type, optional: see Notes)
C1
100nF 63V Polyester Capacitor
C2
220µF 25V Electrolytic Capacitor
D1
LED Red 10mm. Ultra-bright (see Notes)
D2
1N5819 40V 1A Schottky-barrier Diode (see Notes)
IC1
7555 or TS555CN CMos Timer IC
B1
1.5V Battery (AA or AAA cell etc.)
Device purpose:
This circuit is usable as a Night Lamp when a wall mains socket is not available to plug-in an ever running small neon lamp device. In order to ensure minimum battery consumption, one 1.5V cell is used, and a simple voltage doubler drives a pulsating ultra-bright LED: current drawing is less than 500µA.
An optional Photo resistor will switch-off the circuit in daylight or when room lamps illuminate, allowing further current economy.
This device will run for about 3 months continuously on an ordinary AA sized cell or for around 6 months on an alkaline type cell but, adding the Photo resistor circuitry, running time will be doubled or, very likely, triplicated.
Circuit operation:
IC1 generates a square wave at about 4Hz frequency. C2 & D2 form a voltage doubler, necessary to raise the battery voltage to a peak value able to drive the LED.
Notes:
  • IC1 must be a CMos type: only these devices can safely operate at 1.5V supply or less.
  • If you are not needing Photo resistor operation, omit R3 & R4 and connect pin 4 of IC1 to positive supply.
  • Ordinary LEDs can be used, but light intensity will be poor.
  • An ordinary 1N4148 type diode can be used instead of the 1N5819 Schottky-barrier type diode, but LED intensity will be reduced due to the higher voltage drop.
  • Any Schottky-barrier type diode can be used in place of the 1N5819, e.g. the BAT46, rated @ 100V 150mA.
redcircuits.com
