Digital Step-Km Counter
Max. range: 9,950 meters with two digits
Slip it in pants' pocket for walking and jogging
Circuit diagram:
Parts:
R1,R3
22K   1/4W Resistor
R2
2M2 1/4W Resistor
R4
1M   1/4W Resistor
R5,R7,R8
4K7 1/4W Resistor
R6
47R   1/4W Resistor
R9
1K   1/4W Resistor
C1
47nF   63V Polyester Capacitor
C2
100nF   63V Polyester Capacitor
C3
10nF   63V Polyester Capacitor
C4
10µF   25V Electrolytic Capacitor
D1
Common-cathode 7-segment LED mini-display
(Hundreds meters)
D2
(Kilometers)
IC1
4093   Quad 2 input Schmitt NAND Gate IC
IC2
4024   7 stage ripple counter IC
IC3,IC4
4026   Decade counter with decoded 7-segment
display outputs IC
Q1,Q2
BC327   45V 800mA PNP Transistors
P1
SPST Pushbutton (Reset)
P2
SPST Pushbutton (Display)
SW1
SPST Mercury Switch, called also Tilt Switch
SW2
SPST Slider Switch (Sound on-off)
SW3
SPST Slider Switch (Power on-off)
BZ
Piezo sounder
B1
3V Battery (2 AA 1.5V Cells in series)
Device purpose:
This circuit measures the distance covered during a walk. Hardware is located in a small box slipped in pants' pocket and the display is conceived in the following manner: the leftmost display D2 (the most significant digit) shows 0 to 9 Km. and its dot is always on to separate Km. from hm. The rightmost display D1 (the least significant digit) shows hundreds meters and its dot illuminates after every 50 meters of walking. A beeper (excludable), signals each count unit, occurring every two steps.
A normal step was calculated to span around 78 centimeters, thus the LED signaling 50 meters illuminates after 64 steps (or 32 operations of the mercury switch), the display indicates 100 meters after 128 steps and so on. For low battery consumption the display illuminates only on request, pushing on P2. Accidental reset of the counters is avoided because to reset the circuit both pushbuttons must be operated together.
Obviously, this is not a precision meter, but its approximation degree was found good for this kind of device. In any case, the most critical thing to do is the correct placement of the mercury switch inside of the box and the setting of its sloping degree.
Circuit operation:
IC1A & IC1B form a monostable multivibrator providing some degree of freedom from excessive bouncing of the mercury switch. Therefore a clean square pulse enters IC2 that divides by 64. Q2 drives the LED dot-segment of D1 every 32 pulses counted by IC2. Either IC3 & IC4 divide by 10 and drive the displays. P1 resets the counters and P2 enables the displays. IC1C generates an audio frequency square wave that is enabled for a short time at each monostable count. Q1 drives the piezo sounder and SW2 allows to disable the beep.
Notes:
  • Experiment with placement and sloping degree of mercury switch inside the box: this is very critical.
  • Try to obtain a pulse every two walking steps. Listening to the beeper is extremely useful during setup.
  • Trim R6 value to change beeper sound power.
  • Push P1 and P2 to reset.
  • This circuit is primarily intended for walking purposes. For jogging, further great care must be used with mercury switch placement to avoid undesired counts.
  • When the display is disabled current consumption is negligible, therefore SW3 can be omitted.
redcircuits.com
