One-IC two-tones Siren
Double-tone Police sound
Single-tone old ambulance sound
Circuit diagram:
Parts:
R1,R3
470K   1/4W Resistors
R2
680K   1/4W Resistor
R4
82K   1/4W Resistor
R5
330K   1/4W Resistor
R6
10K   1/4W Resistor
R7
33K   1/4W Resistor
R8
3M3 1/4W Resistor
C1,C5
10µF 25V Electrolytic Capacitors
C2,C6
10nF 63V Polyester Capacitors
C3
100nF 63V Polyester Capacitor
C4
100µF 25V Electrolytic Capacitor
D1-D3
1N4148 75V 150mA Diodes
IC1
4093   Quad 2 input Schmitt NAND Gate IC
Q1
BC337   45V 800mA NPN Transistor
P1
SPST Pushbutton
SW1
DPDT Switch
SPKR
8 Ohm Loudspeaker
B1
6V Battery (4 AA 1.5V Cells in series)
Circuit operation:
This circuit is intended for children fun, and can be installed on bicycles, battery powered cars and motorcycles, but also on models and various games and toys. With SW1 positioned as shown in the circuit diagram, the typical dual-tone sound of Police or Fire-brigade cars is generated, by the oscillation of IC1A and IC1B gates. With SW1 set to the other position, the old siren sound increasing in frequency and then slowly decreasing is reproduced, by pushing on P1 that starts oscillation in IC1C and IC1D.
The loudspeaker, driven by Q1, should be of reasonable dimensions and well encased, in order to obtain a more realistic and louder output. Tone and period of the sound oscillations can be varied by changing the values of C1, C2, C5, C6 and/or associated resistors. No power switch is required: leave SW1 in the low position (old-type siren) and the circuit consumption will be negligible.
redcircuits.com
