CC1101 RF modem + 250mW amplifier
Here is my home-built, cloth iron soldered, range extender for CC1101 (included onboard) RF transceiver chip from Texas Instruments. You could say that it is a CC1101+CC2591, but for 868/920MHz band. I used MAX2233 RF amplifier from Maxim-IC. It can deliver up to +24dBm (250mW) of RF amplification with +10dBm of input.
You can download the project files at the bottom of this page by clicking on red "download" button.
Schematic
Click to enlarge
A few basics of CC1101 chip:
  • data transfer speed: 1.2 to 500 kbps
  • frequency: 779-928 MHz
  • output power +10dBm, without PA
  • 2-FSK, GFSK, MSK, OOK and ASK modulation schemes
  • frequency hopping ready
  • automatic address match, package protocol, CRC check
After adding RF amplifier, original power of 10mW is boosted to almost 250mW or 1/4W. MAX2233 RF amp can deliver up to 250mW when powered by 3.6V, and since I used 3.3V LDO on my board, the output RF power is little less than that.
Even though all electronics on this modem work on 3.3V, everything is still compatible with 5V TTL levels which is done with a help of MAX3377 or MAX3378. The power is lowered from 5V to 3.3V by MAX8888 LDO and it can provide enough mA to supply CC1101, MAX3377/8 and the PA.
Testing
For testing I used two modems and two antennas (it figures). At the transmitting side I used monopole antenna for GSM - 900MHz, and for the receiving side I used directional yagi also for GSM - 900MHz. Details of these antennas can be found here: monopole and yagi.
Monopole antenna  Yagi antenna
In this quick test I easily achieved over 1000 meters (or 3300 feet) of range and the test-location/terrain configuration can be seen on the map: Transmitter location, and receiver location. This was achieved even without the antenna on the receiver's side! Then it started to rain and I had to go back. Oh and, I used 1.2 kbps data transfer for maximum receiver sensitivity. The data package transfered was 1 byte address and 4 bytes of payload long.
For testing I used ATmega16 and the source-code can be found in the RAR archive for download.
The parts
All capacitors = eBay shop
All resistors = eBay shop
All inductors = Vishay samples
Q1 26MHz = FOX crystals samples
SMA connector = SparkFun
CC1101 RF modem = Texas Instruments samples
SN74LVC1G04 inverter = Texas Instruments samples
MAX2233 RF PA = MAXIM-IC samples
MAX8888 3v3 LDO = MAXIM-IC samples
MAX3377/MAX3378 converter = MAXIM-IC samples
HMC174MS8 = rfcandy
PCB = BatchPCB. If you need a board for this modem just use my exported gerbers and upload to BatchPCB. Do double-check them out before ordering!
Soldering of components
You would probably think that this board is impossible to solder at home. Well, I will just say that I didn't even touch my board with soldering iron or hot-air reflow iron. It was all soldered by using a solder paste and a home cloth iron. It seems that cloth iron can get hot enough (200 degrees of Celsius) to perfectly solder everything down! It sure was exhausting to place a solder-paste on every pad with a syringe needle. Instead of cloth iron you can use a hot-plate, so check this out and see how it's done.
Partlist
Exported from cc1101.brd at 02.04.2009 15:55:31
EAGLE Version 4.16r2
Part
Value
Package
C1
2.2u
C0603
C2
2.2u
C0603
C3
1.5n
C0603
C4
100n
C0603
C5
47n
C0603
C6
10p
C0603
C7
10p
C0603
C8
100n
C0603
C9
220p
C0603
C10
100p
C0603
C11
1p
C0603
C12
1.5p
C0603
C13
1.5p
C0603
C14
3.3p
C0603
C15
100p
C0603
C16
100p
C0603
C17
68p
C0603
C18
1.5n
C0603
C19
1uF
EIA3216
C20
100p
C0603
C21
47n
C0603
C22
0.22u
C0603
C23
100p
C0603
C24
3.9p
C0603
C25
47n
C0603
C26
47n
C0603
C27
100p
C0603
C28
100p
C0603
IC1
CC1101
QLP-20-NEW
IC3
MAX3377/
MAX3378
TSSOP14
MAX3377
IC5
MAX8888_3v3
SOT23-5
JP1
M09
1X09
L1
12nH
0603
L2
12nH
0603
L3
18nH
0603
L4
18nH
0603
L5
12nH
0603
L6
12nH
0603
L7
15nH
0603
L8
27nH
0603
L9
2.55nH
0603
Q1
26MHz
CRYSTAL-SMD-5X3
R1
56k
R0603
SMA1
SMA_EDGE
SMA-EDGE
SN74LVC1G04 1G04
SOT23-5
U$1
MAX2233
TSSOP16
U2
HMC174MS8
MSOP8
U3
HMC174MS8
MSOP8
elektronika.ba
