One Watt 2.45 GHz Linear Amplifier
RF Micro Devices RF2126
Schematic:
Reversed PCB pattern:
BOM:
Schematic
Reference
Value
Package
Capacitors
C1
1 µF
electrolytic, 10%, 16V
SMT or leaded
C2, C3
1000 pF
ceramic, X7R, 50V
0603 SMT
C4
22 pF
Johanson ceramic 5%, 100V
0504 SMT
C5
3.3 pF
ceramic, ±0.25 pF, 50V NP0
0402 SMT
C6
2 pF
0402 SMT
C7
1.8 pF
0402 SMT
C8
1.6 pF
0402 SMT
Inductors
L1
4.7 nH
2%
0603 SMT
L2
31 ohm @ 100 MHz
ferrite bead, IDC 500 mA
1206 SMT
Resistors
R1
2200 ohm
film, 5%
0603 SMT
R2
1000 ohm
film, 5%
0603 SMT
Integrated Circuits
ICI
RF2126
RF Micro Devices 1 Watt 2.4 GHz power amplifier
SOP-8
Other
J1, J2
PCB mount SMA jacks
Notes:
Part numbers are for reference only. Alternate components may be substituted.
It's also possible to run the RF2126 at around 6.5 volts for slightly more power output. You could try a 7805 voltage regulator with two silicon diodes (or a red LED) in series with the ground lead (cathode to ground).
Be sure to isolate the ground tab on the 7805 though or it won't work. You can even just use a plain old 7806 voltage regulator for 6 volts output.
qsl.net
Fragments of discussion:Full version of discussion »
  • Is this circuit tested? Is it working?
