Michael Fisch EDN In 1940, William Hewlett and David Packard launched a product from a garage. The product was a Wien-bridge oscillator. It consisted of a single-pole highpass filter in series with a single-pole lowpass filter. To keep the gain ...
Victor Khasiev, Linear Technology Design Note 565 Introduction Data loss is a concern in telecom, industrial and automotive applications where embedded systems require a dependable supply of power. Sudden power interruptions can corrupt data during ...
Jordan Dimitrov EDN [Editor’s note: This programmable DC reference calibrator will make a great DIY project for your lab bench. Full design files for the analog portion are provided, leaving the microcontroller part up to you. Send me your ...
Alex Rysin Electronic Design Limiter circuits are often needed to prevent a wide-range signal from overloading the next stage in the signal chain this user-adjustable circuit provides bipolar limiting at precise preset value. As the name implies, a ...
Aaron Schultz, Linear Technology Design Note 563 Introduction A new family of op amps features industry leading speed versus supply current. The LTC6261/LTC6262/LTC6263 family (single, dual, quad) provides 30 MHz at a low 240 uA supply current, ...
George Qian, Linear Technology Design Note 559 Introduction In traditional isolated high voltage flyback converters, tight regulation is achieved using opto-couplers to transfer regulation information from the secondary-side reference circuitry to ...
Thomas Mosteller Electronic Design By using two basic power-supply topologies in conjunction, this circuit provides an easily controlled current source that is well-suited for dimming LEDs Many applications for LED illumination require wide dimming ...
Victor Khasiev, Linear Technology Design Note 561 Introduction Positive to negative conversion (inverting output) is widely used in LCD devices, OLED displays, audio amplifiers, industrial machinery, semiconductor manufacturing process control ...
Victor Khasiev, Linear Technology Design Note 552 Introduction Positive-to-negative DC/DC conversion (inverting output) is widely used in LCD devices, OLED displays, audio amplifiers, industrial equipment, measurement tools, test systems, LED ...
Victor Khasiev, Linear Technology Design Note 558 Introduction The LTC®3110 bidirectional buck-boost DC/DC regulator charges and balances a supercapacitor when a bus voltage is present (for example 3.3 V) and discharges the supercapacitor into ...
