.. work is licensed under a Creative Commons License. This project is featured on pcbheaven.com This project is a full color LED-controller that can be configured via a USB connection. The color of the connected LEDs (common anode only) depends ...
.. project uses 7 RGB LEDs arranged in the form of dice.Each RGB LED has three separate LEDs inside so that makes a total of 21 LEDs and they have been controlled by 4 I/O pins of ...
.. Beerten Introduction In this page we will introduce a great project designed by Toon Beerten. His project named DIY Led Mood Lamp can become a very interesting add-on for your room that's absolutely sure it will impress everyone. As ...
.. CMOS CD4017 Johnson counter The circuit is divided into two portions for easy understanding: Logic control (Figure 1) and LED driver (Figure 2). Figure 1. LED controller. The circuit is controlled by a momentary push switch. Until SW1 is ...
.. Pereira Introduction In this project it was used the Piranha Super-flux RGB LED of common anode, and the PIC18F25K20 , in order to generate combinations of colors. It has two function modes, ...
.. are two reasons for this. If you look at the board layout you will see that this layout allows to either place SMD leds or LED stripes. So if I wanted to place some LED stripe with a common anode then I would need this setup. The other reason ...
.. components, you can use a highly efficient step-down dc/dc converter to create a constant-current, multiple-channel LED driver. It is relatively easy to drive a single-channel LED; however, it becomes more complicated when driving ...
