Data Manual TCM8030 (Texas Instruments) - 8
ManufacturerTexas Instruments
DescriptionBaseband Processor For Analog Cellular Telephones
Pages / Page91 / 8 — List of Tables
File Format / SizePDF / 566 Kb
List of Tables
List of Tables
link to page 44 link to page 45 link to page 47 link to page 62 link to page 64 link to page 65 link to page 65 link to page 66 link to page 66 link to page 66 link to page 67 link to page 68 link to page 68 link to page 69 link to page 69 link to page 69 link to page 70 link to page 71 link to page 71 link to page 71 link to page 72 link to page 73 link to page 74 link to page 74 link to page 74 link to page 75 link to page 75 link to page 75 link to page 76 link to page 76 link to page 77 link to page 77 link to page 78 link to page 79 link to page 80 link to page 80 link to page 81 link to page 82 link to page 83 link to page 83 link to page 85
List of Tables
Table Title Page 5–1 Clock Sources . 5–8 5–2 Master Clock Input Frequency and CLKOUT Select . 5–9 5–3 Power Modes Block Diagram Legend . 5–11 5–4 Write Address Map . 5–26 5–5 Control Word 1 (C1) Definition . 5–28 5–6 Transmit Signal Selection . 5–29 5–7 Operational Control Word 1, Bit 4 Definition C1.4 . 5–29 5–8 Control Word 2 (C2) Definition . 5–30 5–9 Digital Color Codes — Narrowband . 5–30 5–10 SAT Color Codes — Wideband . 5–30 5–11 DSAT Color Codes — Narrowband . 5–31 5–12 Signal Polarity Selection Control Word (C3) Definition . 5–32 5–13 Master Power Enable Modes (C4) Definition . 5–32 5–14 TCM8030 Power Modes . 5–33 5–15 Optional Controls Word 5 (C5) Definition . 5–33 5–16 Interrupt Control Word 1 (IE1) Definition . 5–33 5–17 Interrupt Control Word 2 (IE2) Definition . 5–34 5–18 Transmit Data Word 4 (TXD4) Definition . 5–35 5–19 PIO Control Words (PIO C1,2,3) Definition . 5–35 5–20 PIO3 Interrupt Control (PI3INT, bits 3–0) Definition . 5–35 5–21 PIO3 Interrupt Control (PI3INT bits 7–4) Definition . 5–36 5–22 Narrowband Error Coefficient Setting . 5–37 5–23 SAT Lock Control Definition . 5–38 5–24 TCM8030 Data Processor Test Modes . 5–38 5–25 Data Recovery Observation (DTEST1.2 = 1) . 5–38 5–26 Auxiliary Power Enables (AUXPE) Definition . 5–39 5–27 External Clock and Crystal Frequency Select . 5–39 5–28 Receive-Audio Path Configuration (RXCFG) Control . 5–39 5–29 Transmit-Audio Path Configuration (TXCFG) Control . 5–40 5–30 Microphone and TXDTMF Trim (VDTRIM) Adjust . 5–40 5–31 Limiter Trim Adjust . 5–41 5–32 Transmit SAT TRIM Adjust . 5–41 5–33 Transmit Data Trim (TXDATRIM) Adjust . 5–42 5–34 Transmit Trim (TXTRIM) Adjust . 5–43 5–35 Receive Trim (RXTRIM) Adjust . 5–44 5–36 Loud Speaker Volume Control (VOL CTRL) Adjust . 5–44 5–37 DTMF Tone Output Control . 5–45 5–38 DTMF Mode Control . 5–46 5–39 DAC Range Select (DACRANGE) Definition . 5–47 5–40 AFC Control . 5–47 5–41 Read Address Map . 5–49 viii Document Outline IMPORTANT NOTICE Contents List of Illustrations List of Tables Introduction TCM8030 Features Data Processing Features Audio Processing Features Functional Block Diagram Terminal Assignments Terminal Functions Electrical Specifications Absolute Maximum Ratings Over Operating Free-Air Temperature Range (se\ e Note 1) Recommended Operating Conditions Electrical Characteristics Over Recommended Range of Supply Voltages an\ d Operating Conditions (unless otherwise noted) Electrical Characteristics Over Recommended Operating Conditions, V=3.0\ V, clocked by a crystal oscillator at 5.12 MHz DIGITAL I/Os, V = 3 V Transmit Path Specifications, V = 2.7 V to 3.3 V MICAMP1 and MICAMP2 Voice and DTMF (V/D) Trim, MIC1 to TXO COMPRESSOR, MIC1 to TXO LIMITER, MIC1 to TXO TXTRIM, MIC1 to TXO Transmit Path, MIC1 to TXO Transmit Data at TXO TX-DAT TRIM at TXO Transmit SAT at TXO SAT TRIM at TXO Receive Path Specifications, V = 2.7 V to 3.3 V, V= 171.2 mVrms RXAMP RXTRIM, RXGAIN to REC1 EXPANDOR, RXGAIN to REC1 Receive Path, RXGAIN to REC1 VOL CTRL, RXGAIN to REC1 LS DRIVER, at RECP and RECN, Input at RECIN Receive Data Detect, V = 3 V Receive SAT Detect Miscellaneous Block Specifications, V = 3 V DD 2.6.1 Digital-to-Analog Converters DAC1, DAC2, and DAC3 TCXO Amplifier IF Amplifier DTMF Generator AMP7 Timing Requirements Over Recommended Ranges of Operating Conditions (s\ ee Figure 3…1) Parameter Measurement Information Typical Characteristics Principles of Operation Overview Receive Audio Path Transmit Audio Path Data Processor Miscellaneous Circuits Clocks Power Modes Total Power-Down Mode Shutdown Mode Idle Mode Tone Mode Full Operation Mode, DTMF TX Off Full Operation Mode, DTMF TX On Independent Circuits Circuit Definitions Transmit Path Audio Processing Functions Receive Path Audio Processing Functions Transmit Path Data Processing Functions Receive Path Data Processing Functions Transmit Path SAT Processing Functions Receive Path SAT Processing Functions Miscellaneous Functions Microcontroller Interface Operation Microcontroller Write Operation Address 00 - Operational Control Word 1 (C1) Address 01 - DCC/SAT/DSAT Control Word (C2) Address 02 - Signal Polarity Selection (C3) Address 03 - Master Power Enable Modes (C4) Address 04 - FOCC/FVC Optional Controls (C5) Address 05 - Interrupt Control Word 1 (IE1) Address 06 - Interrupt Control Word 2 (IE2) Address 08 - Commence TX (TXSTART) Address 09 - Start Watchdog (WDSTART) Address 0A - Abort TX (TXABORT) Address 0B - Clear TX Buffer (TXCLEAR) Address 0C - Restart Frame Sync (FRAMESYNC) Address 0D - Reset (RST) Address 0E - Reset Arbitration (ARBITRST) Address 10 - TX Data Word 0 (TXD0) Address 11 - TX Data Word 1 (TXD1) Address 12 - TX Data Word 2 (TXD2) Address 13 - TX Data Word 3 (TXD3) Address 14 - TX Data Word 4 (TXD4) Addresses 15, 17, 19 - PIO Control Words (PIOC1, PIOC2, PIOC3) Addresses 16, 18, 1A - PIO Output Words (PO1, PO2, PO3) Address 1B - PIO3 Pullup Enable Transistors (PI3PULL) Address 1C - PIO3 Interrupt Control (PI3INT) Address 20 - RXRF Idle Mode Timer (RXRFTIM) Address 21 - Counter/Timer Coef (TIMER) Address 22 - Mismatch Wideband Address 23 - FOCC Dotting Coefficient (FCCDOT) - Wideband Address 24 - FVC Dotting Coefficient (FVCDOT) - Wideband Address 25 - Allowed Narrowband Errors (NBCOEF) - Narrowband Address 26 - SAT Lock Determination (SATCOEF) - Wideband Address 2E - Data Processor Test Control 1 (DTEST1) Address 30 - Auxiliary Power Enable (AUXPE) Register Address 31 - Clock Source Frequency Select (CLKSRC) Address 32 - Receive-Audio Path Configuration (RXCFG) Address 33 - Transmit-Audio Path Configuration (TXCFG) Address 34 - Microphone and TX DTMF Trim (VDTRIM) Address 35 - Limiter Trim (LIMITER) Address 36 - Transmit SAT Trim (SAT TRIM) Address 37 - Transmit Data Trim (TXDATRIM) Address 38 - Transmit Trim (TXTRIM) Address 39 - Receive Trim (RXTRIM) Address 3A - Loudspeaker Volume Control (VOL CTRL) Address 3B - DTMF Control (DTMFCTRL) Address 3C - Analog Test Modes (ATEST) Address 40 - DAC Range Select (DACRANGE) Address 41 - DAC1 Data (DAC1DAT) Address 42 - DAC2 Data (DAC2DAT) Address 43 - DAC3 Data (DAC3DAT) Address 44 - AFC control (AFCCTRL) Read Operation Address 00 - Status Word 1 Register (S1) Address 01 - Status Word 2 Register (S2) Address 05 - Event Register 1 (E1) Address 06 - Event Register 2 (E2) Address 10 - RX Data Word 0 (RXD0) Address 11 - RX Data Word 1 (RXD1) Address 12 - RX Data Word 2 (RXD2) Address 13 - RX Data Word 3 (RXD3) Addresses 16, 18, 1A - PIO Status Words (PI1, PI2, PI3) Address 22 - RX Repeat Count (RXRPT)- Wideband Address 25 - Narrowband Error Rate (NBERRS) Address 43 - AFC Terminal Count MS Byte (AFCIF1) Address 44 - AFC Terminal Count Middle Byte (AFCIF2) Address 45 - AFC Terminal Count Lower Byte (AFCIF3) Event Register 1 (E1) Status Definitions RX data available (E1 bit 1) TX buffer available (E1 bit 1) Arbitration failure (E1 bit 2) TX sequence complete (E1 bit 3) Change of FOCC busy/idle (E1 bit 4) Counter/timer reaches zero state (E1 bit 5) Wideband SAT/Narrowband DSAT changed (E1 bit 6) Event Register 2 (E2) Status Definitions FOCC data changed value (E2 bit 0) FVC dotting detected … wideband (E2 bit 1) FVC Frame Sync achieved (E2 bit 2) Change in Frame Sync (E2 bit 3) Change of RXRF idle mode power savings (E2 bit 4) NRZ error count register (NBERRS) updated (E2 bit 5) PIO3 input port sensed signal (E2 bit 6) AFC has reached terminal count (E2 bit 7)
