Datasheet ADA4530-1 (Analog Devices) - 3
DescriptionFemtoampere Input Bias Current Electrometer Amplifier
Pages / Page51 / 3 — ADA4530-1. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 3/16—Rev. 0 …
RevisionB
ADA4530-1. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 3/16—Rev. 0 to Rev. A. 10/15—Revision 0: Initial Version
ADA4530-1 Data Sheet TABLE OF CONTENTS REVISION HISTORY 3/16—Rev 0 to Rev A 10/15—Revision 0: Initial Version
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 4 link to page 6 link to page 8 link to page 10 link to page 10 link to page 10 link to page 11 link to page 12 link to page 12 link to page 21 link to page 27 link to page 29 link to page 29 link to page 29 link to page 30 link to page 31 link to page 31 link to page 31 link to page 31 link to page 32 link to page 33 link to page 33 link to page 34 link to page 34 link to page 34 link to page 35 link to page 35 link to page 37 link to page 38 link to page 39 link to page 39 link to page 40 link to page 43 link to page 43 link to page 43 link to page 43 link to page 44 link to page 44 link to page 44 link to page 45 link to page 45 link to page 45 link to page 46 link to page 47 link to page 47 link to page 50 link to page 50 link to page 51 link to page 51 link to page 30 link to page 30
Features .. 1  Input Bias Current .. 32  Applications ... 1  Input Resistance .. 33  Pin Connection Diagram .. 1  Input Offset Voltage ... 33  General Description ... 1  Insulation Resistance ... 33  Revision History ... 2  Guarding .. 34  Specifications ... 3  Dielectric Relaxation .. 34  5 V Nominal Electrical Characteristics ... 3  Humidity Effects ... 36  10 V Nominal Electrical Characteristics ... 5  Contamination .. 37  15 V Nominal Electrical Characteristics ... 7  Cleaning and Handling ... 38  Absolute Maximum Ratings .. 9  Solder Paste Selection .. 38  Thermal Resistance .. 9  Current Noise Considerations .. 39  ESD Caution .. 9  Layout Guidelines ... 42  Pin Configuration and Function Descriptions ... 10  Physical Implementation of Guarding Techniques.. 42  Typical Performance Characteristics ... 11  Guard Ring .. 42  Main Amplifier, DC Performance .. 11  Guard Plane ... 42  Main Amplifier, AC Performance .. 20  Via Fence ... 43  Guard Amplifier ... 26  Cables and Connectors .. 43  Theory of Operation .. 28  Electrostatic Interferance .. 43  ESD Structure .. 28  Photodiode Interface .. 44  Input Stage ... 28  DC Error Analysis .. 44  Gain Stage .. 29  AC Error Analysis .. 44  Output Stage .. 29  Noise Analysis ... 45  Guard Buffer ... 29  Design Recommendations .. 46  Applications Information .. 30  Design Example .. 46  Input Protection .. 30  Power Supply Recommendations ... 49  Single-Supply and Rail-to-Rail Output ... 30  Power Supply Considerations ... 49  Capacitive Load Stability ... 30  Outline Dimensions ... 50  EMI Rejection Ratio ... 31  Ordering Guide .. 50  High Impedance Measurements ... 32
REVISION HISTORY 3/16—Rev. 0 to Rev. A
Changed DNC Pin to IC Pin .. Throughout Changes to Figure 1 .. 1 Changes to Figure 3 and Table 6 ... 10 Changes to Figure 29 .. 15 Changes to Theory of Operation Section .. 28 Changes to Humidity Effects Section and Figure 112 ... 36 Added Power Supply Recommendations Section, Power Supply Considerations Section, Table 16, and Figure 133 to Figure 135 .. 49
Rev. A | Page 2 of 50 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 5 V NOMINAL ELECTRICAL CHARACTERISTICS 10 V NOMINAL ELECTRICAL CHARACTERISTICS 15 V NOMINAL ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MAIN AMPLIFIER, DC PERFORMANCE MAIN AMPLIFIER, AC PERFORMANCE GUARD AMPLIFIER THEORY OF OPERATION ESD STRUCTURE INPUT STAGE GAIN STAGE OUTPUT STAGE GUARD BUFFER APPLICATIONS INFORMATION INPUT PROTECTION SINGLE-SUPPLY AND RAIL-TO-RAIL OUTPUT CAPACITIVE LOAD STABILITY EMI REJECTION RATIO HIGH IMPEDANCE MEASUREMENTS INPUT BIAS CURRENT INPUT RESISTANCE INPUT OFFSET VOLTAGE INSULATION RESISTANCE GUARDING DIELECTRIC RELAXATION HUMIDITY EFFECTS CONTAMINATION CLEANING AND HANDLING SOLDER PASTE SELECTION CURRENT NOISE CONSIDERATIONS LAYOUT GUIDELINES PHYSICAL IMPLEMENTATION OF GUARDING TECHNIQUES GUARD RING GUARD PLANE VIA FENCE CABLES AND CONNECTORS ELECTROSTATIC INTERFERANCE PHOTODIODE INTERFACE DC ERROR ANALYSIS AC ERROR ANALYSIS NOISE ANALYSIS DESIGN RECOMMENDATIONS DESIGN EXAMPLE POWER SUPPLY RECOMMENDATIONS POWER SUPPLY CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
