Datasheet ADA4177-1, ADA4177-2, ADA4177-4 (Analog Devices) - 8
DescriptionOVP and EMI Protected, Precision, Low Noise and Bias Current Single Op Amp
Pages / Page31 / 8 — ADA4177-1/ADA4177-2/ADA4177-4. Data Sheet. PIN CONFIGURATIONS AND …
RevisionE
File Format / SizePDF / 868 Kb
ADA4177-1/ADA4177-2/ADA4177-4. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. NIC. –IN. ADA4177-1 7 V+. TOP VIEW. +IN. OUT
ADA4177-1/ADA4177-2/ADA4177-4 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS NIC –IN ADA4177-1 7 V+ TOP VIEW +IN OUT
ADA4177-1/ADA4177-2/ADA4177-4 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS NIC 1 8 NIC NIC 1 8 NIC –IN 2 ADA4177-1 7 V+ –IN 2 ADA4177-1 7 V+ TOP VIEW +IN 3 6 OUT TOP VIEW (Not to Scale) +IN 3 6 OUT (Not to Scale) V– 4 5 NIC V– 4 5 NIC
205
NOTES
105
NOTES 1. NIC = NOT INTERNALLY CONNECTED.
12282-
12282- Figure 3. 8-Lead MSOP Pin Configuration, ADA4177-1 Figure 4. 8-Lead SOIC Pin Configuration, ADA4177-1
Table 6. ADA4177-1 P in Function Descriptions Pin No. Mnemonic Description
1, 5, 8 NIC Not Internally Connected. 2 −IN Inverting Input Channel. 3 +IN Noninverting Input Channel. 4 V− Negative Supply Voltage. 6 OUT Output Channel. 7 V+ Positive Supply Voltage. Rev. C | Page 8 of 31 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS, ±5 V ELECTRICAL CHARACTERISTICS, ±15 V ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION ACTIVE OVERVOLTAGE PROTECTION Common Protection Methods Add an External Series Input Resistor Add External Clamping Diodes Input Protection Circuit LIMITING OVERVOLTAGE CURRENT OUT OF THE POSITIVE SUPPLY PIN EMI PROTECTION SELF HEATING USING THE ADA4177-1/ADA4177-2/ADA4177-4 AS A COMPARATOR OUTPUT PHASE REVERSAL PROPER PRINTED CIRCUIT BOARD (PCB) LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE
