Datasheet AD713 (Analog Devices) - 7
DescriptionPrecision, High Speed, BiFET Quad Op Amp
Pages / Page21 / 7 — AD713. TYPICAL PERFORMANCE CHARACTERISTICS. RL = 2kΩ. TA = 25°C. ) V 15. …
RevisionC
File Format / SizePDF / 387 Kb
AD713. TYPICAL PERFORMANCE CHARACTERISTICS. RL = 2kΩ. TA = 25°C. ) V 15. A) 12. m (. S E G 10. CURRE. N CE. T V. SUPPLY VOLTAGE (±V)
AD713 TYPICAL PERFORMANCE CHARACTERISTICS RL = 2kΩ TA = 25°C ) V 15 A) 12 m ( S E G 10 CURRE N CE T V SUPPLY VOLTAGE (±V)
VS = ±15 V at TA = 25°C, unless otherwise noted.
20 16 RL = 2kΩ TA = 25°C ) V 15 ( A) 12 G m ( IN T W N S E G 10 A 8 CURRE LT T O N CE T V S U E P 5 UI IN 4 Q 0 0 0 5 10 15 20
03 06 0
0 5 10 15 20
0 4- 4-
SUPPLY VOLTAGE (±V)
82
SUPPLY VOLTAGE (V)
82 00 00 Figure 3. Input Voltage Swing vs. Supply Voltage Figure 6. Quiescent Current vs. Supply Voltage
20 10–6 RL = 2kΩ TA = 25°C ) 10–7 (V 15 G A) IN ( +VOUT 10–8 NT SW E G A 10 T 10–9 L CURRE –VOUT AS VO T BI U P 10–10 UT T U 5 O INP 10–11 0 10–12 0 5 10 15 20
004 07 4-
–60 –40 –20 0 20 40 60 80 100 120 140
04-
SUPPLY VOLTAGE (±V)
82 00
TEMPERATURE (°C)
82 0 0 Figure 4. Output Voltage Swing vs. Supply Voltage Figure 7. Input Bias Current vs. Temperature
30 100 ) 25 -p p ) 10 (V G 20 ( IN CE ±15V SUPPLIES E SW DAN G 15 E P 1 A T M L I T U VO 10 P T U UT P T O 0.1 U O 5 0
5
0.01
8
10 100 1k 10k
-00
1k 10k 100k 1M 10M
00 24
LOAD RESISTANCE (Ω)
24- 008
FREQUENCY (Hz)
008 Figure 5. Output Voltage Swing vs. Load Resistance Figure 8. Output Impedance vs. Frequency, G = 1 Rev. F | Page 6 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION MEASURING AD713 SETTLING TIME POWER SUPPLY BYPASSING A HIGH SPEED INSTRUMENTATION AMPLIFIER CIRCUIT A HIGH SPEED 4-OP-AMP CASCADED AMPLIFIER CIRCUIT HIGH SPEED OP AMP APPLICATIONS AND TECHNIQUES DAC Buffers (I-to-V Converters) Driving the Analog Input of an Analog-to-Digital Converter Driving A Large Capacitive Load CMOS DAC APPLICATIONS FILTER APPLICATIONS A Programmable State Variable Filter GIC AND FDNR FILTER APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
