Datasheet AD713 (Analog Devices) - 9
DescriptionPrecision, High Speed, BiFET Quad Op Amp
Pages / Page21 / 9 — AD713. 100. VS = ±15V. 3V RMS. CM = 1V p-p. L = 2kΩ. A = 25°C. L = 100pF. …
RevisionC
File Format / SizePDF / 387 Kb
AD713. 100. VS = ±15V. 3V RMS. CM = 1V p-p. L = 2kΩ. A = 25°C. L = 100pF. R (. D (. 110. 120. 130. 10k. 100k. FREQUENCY (Hz). RL = 2kΩ TA = 25°C. ) Hz
AD713 100 VS = ±15V 3V RMS CM = 1V p-p L = 2kΩ A = 25°C L = 100pF R ( D ( 110 120 130 10k 100k FREQUENCY (Hz) RL = 2kΩ TA = 25°C ) Hz
AD713 100 70 VS = ±15V 3V RMS V R CM = 1V p-p L = 2kΩ T C A = 25°C 80 L = 100pF 80 90 60 B) B) d d R ( 100 D ( M H C T 40 110 20 120 0
5
130 10 100 1k 10k 100k 1M
01
100 1k 10k 100k
0184- 24-
FREQUENCY (Hz) FREQUENCY (Hz)
008 0082 Figure 15. Common-Mode Rejection vs. Frequency Figure 18. Total Harmonic Distortion vs. Frequency
30 1k RL = 2kΩ TA = 25°C 25 VS = ±15V ) Hz p) V/ p- n V 20 100 ( E ( G GE A T L LTA 15 O VO V T U ISE 10 O TP 10 N T OU PU IN 5 0
6
1
19
100k 1M 10M
01
1 10 100 1k 10k 100k
0 24-
INPUT FREQUENCY (Hz) FREQUENCY (Hz)
824- 008 00 Figure 16. Large Signal Frequency Response Figure 19. Input Noise Voltage Spectral Density
10 25 8 OLTS V 6 20 L ± A N 4 s) /µ 2 TO FI V 15 V 1% 0.1% 0.01% 0 E ( T 0 A OM ERROR 1% 0.1% 0.01% –2 10 EW R G FR IN SL –4 W T S –6 U 5 TP –8 OU –10 0 0.5 0.6 0.7 0.8 0.9 1.0
017
0 100 200 300 400 500 600 700 800 900
4- 20 0
SETTLING TIME (µs) INPUT ERROR SIGNAL (mV)
4- 0082
(AT SUMMING JUNCTION)
082 0 Figure 17. Output Swing and Error vs. Settling Time Figure 20. Slew Rate vs. Input Error Signal Rev. F | Page 8 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION MEASURING AD713 SETTLING TIME POWER SUPPLY BYPASSING A HIGH SPEED INSTRUMENTATION AMPLIFIER CIRCUIT A HIGH SPEED 4-OP-AMP CASCADED AMPLIFIER CIRCUIT HIGH SPEED OP AMP APPLICATIONS AND TECHNIQUES DAC Buffers (I-to-V Converters) Driving the Analog Input of an Analog-to-Digital Converter Driving A Large Capacitive Load CMOS DAC APPLICATIONS FILTER APPLICATIONS A Programmable State Variable Filter GIC AND FDNR FILTER APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
