21 /8 — AD795. 1.00. NOISE BANDWIDTH: 0.1Hz TO 10Hz. 0.95. A) 0.90. p 100. NT …
Revision
C
PDF / 334 Kb
AD795. 1.00. NOISE BANDWIDTH: 0.1Hz TO 10Hz. 0.95. A) 0.90. p 100. NT 0.85. V (µ. E IS. 0.80. CUR. 0.75. A T. 0.70. INP. 0.65. 0.60. –15. –10. 10k. 100k. 10M. 100M
AD7951.001kNOISE BANDWIDTH: 0.1Hz TO 10Hz0.95A) 0.90)p-p(p 100NT 0.85V (µREE IS0.80OCURNASE0.75GBIA T10UTL0.70INPVO0.650.601 3 –15–10–5051015 100 1k10k100k1M10M100M1G 01 5- 5- COMMON-MODE VOLTAGE (V) 84 SOURCE RESISTANCE (Ω) 84 00 00 Figure 10. Input Bias Current vs. Common-Mode Voltage Figure 13. Input Voltage Noise vs. Source Resistance 10–450SAMPLE SIZE = 34410–5–I+I10–6ININ40Sf = 0.1Hz TO 10Hz(A)10–7ITNT EUN10–8F 30O E10–9CURRAGAS 10–10NT 20BI UT 10–11RCEPEINP10–121010–1310–140 14 –6–5–4–3–2–10123456 110 0123 0 5- 5- DIFFERENTIAL INPUT VOLTAGE (±V) 84 INPUT VOLTAGE NOISE (µV p-p) 84 00 00 Figure 11. Input Bias Current vs. Differential Input Voltage Figure 14. Typical Distribution of Input Voltage Noise 15.0100)1kf = 1kHzHz V/ ) (n T) 12.510)U PHzHzN IV/100OnfA/ (TE (VOLTAGE NOISEED EISISRO 10.01NOERE NEFGNTRA T10LCURRENT NOISEURREISE (VO7.50.1CO E N G A T L O5.00.01V 2 1 5 –60–40–20020406080100120140 01 1101001k10k100k1M10M 01 5- 5- TEMPERATURE (°C) 84 FREQUENCY (Hz) 84 00 00 Figure 12. Voltage and Current Noise Spectral Density vs. Temperature Figure 15. Input Voltage Noise Spectral Density Rev. C | Page 7 of 20 Document Outline Features Applications Connection Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Minimizing Input Current Circuit Board Notes Offset Nulling AC Response with High Value Source and Feedback Resistance Overload Issues Input Protection Preamplifier Applications Minimizing Noise Contributions Using a T Network A pH Probe Buffer Amplifier Outline Dimensions Ordering Guide
