Datasheet AD818 (Analog Devices) - 3
DescriptionLow Cost, Low Power Video Op Amp
Pages / Page16 / 3 — AD818–SPECIFICATIONS (@ TA = 25. C, unless otherwise noted.). AD818A. …
RevisionD
File Format / SizePDF / 630 Kb
AD818–SPECIFICATIONS (@ TA = 25. C, unless otherwise noted.). AD818A. Parameter. Conditions. Min. Typ. Max. Unit
AD818–SPECIFICATIONS (@ TA = 25 C, unless otherwise noted.) AD818A Parameter Conditions Min Typ Max Unit
AD818
C, unless otherwise noted.) AD818A Parameter Conditions VS Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Bandwidth Gain = +2 ±5 V 70 95 MHz ±15 V 100 130 MHz 0 V, +5 V 40 55 MHz Gain = –1 ±5 V 50 70 MHz ±15 V 70 100 MHz 0 V, +5 V 30 50 MHz Bandwidth for 0.1 dB Flatness Gain = +2 ±5 V 20 43 MHz CC = 2 pF ±15 V 40 55 MHz 0 V, +5 V 10 18 MHz Gain = –1 ±5 V 18 34 MHz CC = 2 pF ±15 V 40 72 MHz 0 V, +5 V 10 19 MHz Full Power Bandwidth* VOUT = 5 V p-p RLOAD = 500 W ±5 V 25.5 MHz VOUT = 20 V p-p RLOAD = 1 kW ±15 V 8.0 MHz Slew Rate RLOAD = 1 kW ±5 V 350 400 V/ms Gain = –1 ±15 V 450 500 V/ms 0 V, +5 V 250 300 V/ms Settling Time to 0.1% –2.5 V to +2.5 V ±5 V 45 ns 0 V–10 V Step, AV = –1 ±15 V 45 ns Settling Time to 0.01% –2.5 V to +2.5 V ±5 V 80 ns 0 V–10 V Step, AV = –1 ±15 V 80 ns Total Harmonic Distortion FC = 1 MHz ±15 V 63 dB Differential Gain Error NTSC ±15 V 0.005 0.01 % (RL = 150 W) Gain = +2 ±5 V 0.01 0.02 % 0 V, +5 V 0.08 % Differential Phase Error NTSC ±15 V 0.045 0.09 Degrees (RL = 150 W) Gain = +2 ±5 V 0.06 0.09 Degrees 0 V, +5 V 0.1 Degrees Cap Load Drive 10 pF INPUT OFFSET VOLTAGE ±5 V to ±15 V 0.5 2 mV TMIN to TMAX 3 mV Offset Drift 10 mV/∞C INPUT BIAS CURRENT ±5 V, ±15 V 3.3 6.6 mA TMIN 10 mA TMAX 4.4 mA INPUT OFFSET CURRENT ±5 V, ±15 V 25 300 nA TMIN to TMAX 500 nA Offset Current Drift 0.3 nA/∞C OPEN-LOOP GAIN VOUT = ± 2.5 V ±5 V RLOAD = 500 W 3 5 V/mV TMIN to TMAX 2 V/mV RLOAD = 150 W 2 4 V/mV VOUT = ± 10 V ±15 V RLOAD = 1 kW 6 9 V/mV TMIN to TMAX 3 V/mV VOUT = ± 7.5 V ±15 V RLOAD = 150 W (50 mA Output) 3 5 V/mV COMMON-MODE REJECTION VCM = ± 2.5 V ±5 V 82 100 dB VCM = ± 12 V ±15 V 86 120 dB T ± MIN to TMAX 15 V 84 100 dB –2– REV. D Document Outline Untitled
