Datasheet ADR3412, ADR3420, ADR3425, ADR3430, ADR3433, ADR3440, ADR3450 (Analog Devices)
DescriptionMicro-Power, High-Accuracy 3.3V Voltage Reference
Pages / Page24 / 1 — Micropower, High Accuracy. Voltage References. …
RevisionC
File Format / SizePDF / 916 Kb
Micropower, High Accuracy. Voltage References. ADR3412/ADR3420/ADR3425/ADR3430/ADR3433/ADR3440/ADR3450. FEATURES
Datasheet ADR3412, ADR3420, ADR3425, ADR3430, ADR3433, ADR3440, ADR3450 Analog Devices, Revision: C
Micropower, High Accuracy Voltage References ADR3412/ADR3420/ADR3425/ADR3430/ADR3433/ADR3440/ADR3450 FEATURES PIN CONFIGURATION Initial accuracy: ±0.1% (maximum) GND FORCE 1 6 VOUT FORCE Maximum temperature coefficient: 8 ppm/°C ADR34xx Operating temperature range: −40°C to +125°C GND SENSE 2 5 VOUT SENSE Output current: +10 mA source/−3 mA sink
1
TOP VIEW
00 0-
Low quiescent current: 100 μA (maximum) ENABLE 3 4 V (Not to Scale) IN
44 08
Low dropout voltage: 250 mV at 2 mA
Figure 1. 6-Lead SOT-23
Output noise (0.1 Hz to 10 Hz): <10 μV p-p at 1.2 V (typical) 6-lead SOT-23 APPLICATIONS Precision data acquisition systems Industrial instrumentation Medical devices Battery-powered devices GENERAL DESCRIPTION
The ADR3412/ADR3420/ADR3425/ADR3430/ADR3433/
Table 2. Voltage Reference Choices from Analog Devices
ADR3440/ADR3450 are low cost, low power, high precision
High Voltage,
CMOS voltage references, featuring ±0.1% initial accuracy, low
VOUT Low Cost/ Ultralow Low High Perfor-
operating current, and low output noise in a small SOT-23
(V) Low Power Power Noise mance
package. For high accuracy, output voltage and temperature 0.5/1.0 ADR130 coefficient are trimmed digitally during final assembly using 1.2 ADR3412 Analog Devices, Inc., patented DigiTrim® technology. ADR280 2.048 ADR360 REF191 ADR430 Stability and system reliability are further improved by the low ADR3420 ADR440 output voltage hysteresis of the device and low long-term output 2.5 ADR3425 ADR291 ADR431 ADR03 voltage drift. Furthermore, the low operating current of the AD1582 REF192 ADR441 AD780 device (100 μA maximum) facilitates usage in low power ADR361 devices, and its low output noise helps maintain signal integrity 3.0 ADR3430 REF193 ADR433 ADR06 in critical signal processing systems. AD1583 These CMOS are available in a wide range of output voltages, all ADR363 ADR443 AD780 of which are specified over the industrial temperature range of 3.3 ADR366 REF196 −40°C to +125°C. ADR3433
Table 1. Selection Guide
4.096 ADR3440 ADR292 ADR434
Model Output Voltage (V) Input Voltage Range (V)
AD1584 ADR3412 1.200 2.3 to 5.5 ADR364 REF198 ADR444 ADR3420 2.048 2.3 to 5.5 5.0 ADR3450 ADR293 ADR435 ADR02 ADR3425 2.500 2.7 to 5.5 AD1585 REF195 ADR445 ADR3430 3.000 3.2 to 5.5 ADR365 AD586 ADR3433 3.300 3.5 to 5.5 10.0 ADR01 ADR3440 4.096 4.3 to 5.5 AD587 ADR3450 5.000 5.2 to 5.5
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2010 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ADR3412 ELECTRICAL CHARACTERISTICS ADR3420 ELECTRICAL CHARACTERISTICS ADR3425 ELECTRICAL CHARACTERISTICS ADR3430 ELECTRICAL CHARACTERISTICS ADR3433 ELECTRICAL CHARACTERISTICS ADR3440 ELECTRICAL CHARACTERISTICS ADR3450 ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS AND MINIMUM OPERATING CONDITION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION LONG-TERM STABILITY POWER DISSIPATION APPLICATIONS INFORMATION BASIC VOLTAGE REFERENCE CONNECTION INPUT AND OUTPUT CAPACITORS 4-WIRE KELVIN CONNECTIONS VIN SLEW RATE CONSIDERATIONS SHUTDOWN/ENABLE FEATURE SAMPLE APPLICATIONS Negative Reference Bipolar Output Reference Boosted Output Current Reference OUTLINE DIMENSIONS ORDERING GUIDE
