NCP1200 1 Adj 8 HV Current HV Source Skip Cycle 75.5 k 1.4 V Comparator + UVLO 2 Internal - 7 FB High and Low V NC CC Internal Regulator 29 k Q Flip−Flop Current 3 250 ns 40, 60 or Set DCmax = 80% Q 6 Sense L.E.B. 100 kHz VCC Reset Clock + 8 k 60 k 4 - Ground 5 Drv + Vref 1 V 20 k ±250 mA - 5.2 V Overload? Fault Duration Figure 2. Internal Circuit ArchitectureMAXIMUM RATINGS ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ RatingSymbolValueUnits ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁ Power Supply Voltage VCC 16 V ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁ ÁÁÁÁÁÁ Thermal Resistance Junction−to−Air, PDIP−8 version RqJA 100 °C/W ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁ ÁÁÁÁÁÁ Thermal Resistance Junction−to−Air, SOIC version RqJA 178 ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ Thermal Resistance Junction−to−Case ÁÁÁÁÁ R ÁÁÁÁÁÁ ÁÁÁÁ qJC 57 ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁ Maximum Junction Temperature T ÁÁÁÁÁÁ Jmax 150 °C Typical Temperature Shutdown 140 ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ − ÁÁÁÁÁÁ ÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁ Storage Temperature Range ÁÁÁÁÁ Tstg ÁÁÁÁÁÁ −60 to +150 °C ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁ ESD Capability, HBM Model (All Pins except VCC and HV) ÁÁÁÁÁ − ÁÁÁÁÁÁ 2.0 kV ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁ ESD Capability, Machine Model ÁÁÁÁÁ − ÁÁÁÁÁÁ 200 V ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁ Maximum Voltage on Pin 8 (HV), pin 6 (VCC) Grounded ÁÁÁÁÁ − ÁÁÁÁÁÁ 450 V ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁ Maximum Voltage on Pin 8 (HV), Pin 6 (VCC) Decoupled to Ground with 10 mF ÁÁÁÁÁ − ÁÁÁÁÁÁ 500 V ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁ Minimum Operating Voltage on Pin 8 (HV) ÁÁÁÁÁ − ÁÁÁÁÁÁ 30 V Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality ÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁÁ ÁÁÁÁÁ ÁÁÁÁÁÁ ÁÁÁÁ should not be assumed, damage may occur and reliability may be affected. 1. This device series contains ESD protection rated using the following tests: Human Body Model (HBM) 2000 V per JEDEC Standard JESD22, Method A114E. Machine Model (MM) 200 V per JEDEC Standard JESD22, Method A115A. www.onsemi.com3
