Datasheet AD823A (Analog Devices) - 2
Description17 MHz, Rail-to-Rail FET Input Dual Amplifier
Pages / Page21 / 2 — AD823A* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 580 Kb
AD823A* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD823A* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD823A Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • Universal Evaluation Board for Dual High Speed • Symbols and Footprints Operational Amplifiers
DISCUSSIONS DOCUMENTATION
View all AD823A EngineerZone Discussions.
Data Sheet
• AD823A: Wide Supply Dual, 17 MHz, Rail-to-Rail FET Input
SAMPLE AND BUY
Amplifier Datasheet Visit the product page to see pricing options.
User Guides
• UG-128: Universal Evaluation Board for Dual High Speed
TECHNICAL SUPPORT
Op Amps in SOIC Packages Submit a technical question or find your regional support • UG-886: Universal Evaluation Board for Dual High Speed number. Op Amps Offered in 8-Lead MSOP
DOCUMENT FEEDBACK TOOLS AND SIMULATIONS
Submit feedback for this data sheet. • Analog Filter Wizard • Analog Photodiode Wizard • AD823A SPICE Macro-Model
Document Outline Features Applications General Description Connection Diagram Revision History Specifications 5 V Operation 3.3 V Operation ±15 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Output Impedance Applications Information Input Characteristics Output Characteristics Wideband Photodiode Preamp Active Filter Maximizing Performance Through Proper Layout Outline Dimensions Ordering Guide
