Datasheet NCS20071, NCV20071, NCS20072, NCV20072, NCS20074, NCV20074 (ON Semiconductor) - 7
ManufacturerON Semiconductor
DescriptionOperational Amplifier, Wide supply range, 3Mhz CMOS Op-Amp
Pages / Page25 / 7 — NCS20071, NCV20071, NCS20072, NCV20072, NCS20074, NCV20074. ELECTRICAL …
Revision14
File Format / SizePDF / 950 Kb
NCS20071, NCV20071, NCS20072, NCV20072, NCS20074, NCV20074. ELECTRICAL CHARACTERISTICS AT VS = 2.7 V. Boldface. Parameter
NCS20071, NCV20071, NCS20072, NCV20072, NCS20074, NCV20074 ELECTRICAL CHARACTERISTICS AT VS = 2.7 V Boldface Parameter
link to page 7 link to page 7 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8
TA = 25°C; RL ≥ 10 kW; VCM = VOUT = mid−supply unless otherwise noted. All limits are guaranteed by testing or statistical analysis.
Boldface
limits apply over the specified temperature range, TA = −40°C to 125°C. (Notes 11, 12)
Parameter Symbol Conditions Min Typ Max Unit NOISE CHARACTERISTICS
Total Harmonic Distortion plus Noise THD+N VIN = 0.5 Vpp, f = 1 kHz, Av = 1 0.05 % f = 1 kHz 30 Input Referred Voltage Noise en nV/√Hz f = 10 kHz 20 Input Referred Current Noise in f = 1 kHz 90 fA/√Hz
SUPPLY CHARACTERISTICS
114 135 Power Supply Rejection Ratio PSRR No Load dB
100
420 625 NCx20071 No load
765
Power Supply Quiescent Current IDD mA 405 525 NCx20072, NCx20074 Per channel, no load
625
Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 11. Refer to ABSOLUTE MAXIMUM RATINGS and APPLICATION INFORMATION for Safe Operating Area. 12. Performance guaranteed over the indicated operating temperature range by design and/or characterization. 13. Power dissipation must be limited to prevent junction temperature from exceeding 150°C. See Absolute Maximum Ratings for more infor- mation.
ELECTRICAL CHARACTERISTICS AT VS = 5 V
Boldface
limits apply over the specified temperature range, TA = −40°C to 125°C. (Notes 14, 15)
Parameter Symbol Conditions Min Typ Max Unit INPUT CHARACTERISTICS
1.3 ±3.5 NCx20071 +
4.5
Input Offset Voltage VOS mV 1.3 ±3 NCx20072, NCx20074 +
4
Offset Voltage Drift DVOS/DT TA = 25°C to 125 °C 2 mV/°C 5 200 Input Bias Current (Note 15) IIB pA
1500
2 75 NCx20071, NCx20072
500
Input Offset Current (Note 15) IOS pA 2 75 NCx20074
200
NCx20072 100 Channel Separation XTLK DC dB NCx20074 115 Differential Input Resistance RID 5 GW Common Mode Input Resistance RIN 5 GW Differential Input Capacitance CID 1.5 pF Common Mode Input Capacitance CCM 3.5 pF Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 14. Refer to ABSOLUTE MAXIMUM RATINGS and APPLICATION INFORMATION for Safe Operating Area. 15. Performance guaranteed over the indicated operating temperature range by design and/or characterization. 16. Power dissipation must be limited to prevent junction temperature from exceeding 150°C. See Absolute Maximum Ratings for more infor- mation.
www.onsemi.com 7
