Datasheet MAX4236, MAX4237 (Maxim) - 5
ManufacturerMaxim
DescriptionSOT23, Very High Precision, 3V/5V Rail-to-Rail Op Amps
Pages / Page14 / 5 — SOT23, Very High Precision, 3V/5V. Rail-To-Rail Op Amps. MAX4236/MAX4237. …
File Format / SizePDF / 466 Kb
SOT23, Very High Precision, 3V/5V. Rail-To-Rail Op Amps. MAX4236/MAX4237. ELECTRICAL CHARACTERISTICS (SOT23-6) (continued)
SOT23, Very High Precision, 3V/5V Rail-To-Rail Op Amps MAX4236/MAX4237 ELECTRICAL CHARACTERISTICS (SOT23-6) (continued)
(VCC = +2.4V to +5.5V, VEE = 0, VCM = 0, VOUT = VCC/2, RL = 100kΩ to VCC/2, TA = TMIN to TMAX, unless otherwise noted. Typical values are at VCC = +5V and TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
TA = +25°C 97 120 V Power-Supply Rejection Ratio PSRR CC = +2.4V to dB +5.5V TA = TMIN to TMAX 95 RL = 100kΩ, VOUT = 15mV to 110 128 VCC = +5V, RL (V connected to CC - 50mV) VCC/2, RL = 1kΩ, TA = +25°C VOUT = 0.15V 100 114 to (VCC - 0.3V) RL = 100kΩ, VOUT = VCC = +5V, RL 110 15mV to (VCC - 50mV) connected to VCC/2, R T L = 1kΩ, A = TMIN to V 95 T OUT = 0.15V to MAX (VCC - 0.3V) Large-Signal Voltage Gain AVOL dB RL = 100kΩ, VOUT = 15mV to 110 128 VCC = +3V, RL (VCC - 50mV) connected to VCC/2, RL = 1kΩ, TA = +25°C VOUT = 0.15V to 100 114 (VCC - 0.3V) RL = 100kΩ, VCC = +3V, RL VOUT = 15mV to 105 connected to (VCC - 50mV) VCC/2, R T L = 1kΩ, A = TMIN to V 95 T OUT = 0.15V to MAX (VCC - 0.3V) VCC - VOH 2 10 VCC = +5V, RL connected to VCC/2, RL = 100kΩ VOL - VEE 3 10 Output Voltage Swing VOUT mV VCC - VOH 150 250 VCC = +5V, RL connected to VCC/2, RL = 1kΩ VOL - VEE 50 100 Shorted to VEE 10 Output Short-Circuit Current IOUT(SC) mA Shorted to VCC 30 MAX4236 1.7 Gain-Bandwidth Product GBWP RL = ∞, CL = 15pF MHz MAX4237 7.5 V MAX4236 0.3 CC = +5V, Slew Rate SR V/µs VOUT = 4V step MAX4237 1.3
_______________________________________________________________________________________ 5
