Datasheet MAX4236, MAX4237 (Maxim) - 8
ManufacturerMaxim
DescriptionSOT23, Very High Precision, 3V/5V Rail-to-Rail Op Amps
Pages / Page14 / 8 — SOT23, Very High Precision, 3V/5V Rail-To-Rail Op Amps. Typical Operating …
File Format / SizePDF / 466 Kb
SOT23, Very High Precision, 3V/5V Rail-To-Rail Op Amps. Typical Operating Characteristics (continued)
SOT23, Very High Precision, 3V/5V Rail-To-Rail Op Amps Typical Operating Characteristics (continued)
(VCC = +5V, VEE = 0, VCM = VCC/2, RL = 100kΩ to VCC/2, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT vs. TEMPERATURE SUPPLY CURRENT vs. SUPPLY VOLTAGE LARGE-SIGNAL GAIN vs. TEMPERATURE
400 345 RL = 1kΩ 390 140 380 MAX4236 toc13 340 MAX4236 toc14 MAX4236 toc15 T V A = -40°C CC = 5V, RL to VEE µA) 370 µA) V 335 TA = +25°C 120 CC = 5V, RL to VCC 360 TA = +85°C 350 330 +V = 5V T GAIN (dB) 100 340 A = +125°C VCC = 3V, RL to VEE 325 SUPPLY CURRENT ( 330 SUPPLY CURRENT ( VCC = 3V, RL to VCC 320 +V = 3V 80 320 310 300 315 60 -50 -25 0 25 50 75 100 125 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -50 -25 0 25 50 75 100 125
MAX4236/MAX4237
TEMPERATURE (°C) SUPPLY VOLTAGE (V) TEMPERATURE (°C)
MINIMUM OUTPUT VOLTAGE MAXIMUM OUTPUT VOLTAGE OUTPUT VOLTAGE vs. TEMPERATURE vs. TEMPERATURE vs. SUPPLY VOLTAGE
50 200 200 RL = 1kΩ 45 180 180 40 MAX4236 toc16 160 MAX4236 toc17 VCC = 5V, RL = 1kΩ 160 MAX4236 toc18 VCC = 5V, RL = 1kΩ 35 140 140 VCC - VOH, RL to VCC 30 120 120 VCC = 3V, RL = 1kΩ VCC = 3V, RL = 1kΩ 25 100 100 20 80 80 15 60 OUTPUT VOLTAGE (mV) 60 V 10 OL - VEE, RL to VEE MINIMUM OUTPUT VOLTAGE (mV) 40 40 MAXIMUM OUTPUT VOLTAGE (mV) V 5 CC = 5V/3V, RL = 100kΩ 20 20 VCC = 5V/3V, RL = 100kΩ 0 0 0 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 3.0 3.5 4.0 4.5 5.0 TEMPERATURE (°C) TEMPERATURE (°C) SUPPLY VOLTAGE (V)
OUTPUT VOLTAGE OUTPUT SOURCE CURRENT OUTPUT SOURCE CURRENT vs. SUPPLY VOLTAGE vs. OUTPUT VOLTAGE vs. OUTPUT VOLTAGE
4.0 12 10 R V L = 100kΩ V CC = 3V CC = 5V 9 3.5 10 MAX4236 toc19 VOL - VEE MAX4236 toc20 8 MAX4236 toc21 3.0 7 8 2.5 6 2.0 6 5 4 1.5 VCC - VOH 4 OUTPUT VOLTAGE (mV) 3 1.0 OUTPUT SOURCE CURRENT (mA) 2 2 OUTPUT SOURCE CURRENT (mA) 0.5 1 0 0 0 3.0 3.5 4.0 4.5 5.0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 0 0.5 1.0 1.5 2.0 2.5 3.0 SUPPLY VOLTAGE (V) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V)
8 _______________________________________________________________________________________
