Datasheet MAX4236, MAX4237 (Maxim) - 9
Manufacturer | Maxim |
Description | SOT23, Very High Precision, 3V/5V Rail-to-Rail Op Amps |
Pages / Page | 14 / 9 — SOT23, Very High Precision, 3V/5V. Rail-To-Rail Op Amps. MAX4236/MAX4237. … |
File Format / Size | PDF / 466 Kb |
SOT23, Very High Precision, 3V/5V. Rail-To-Rail Op Amps. MAX4236/MAX4237. Typical Operating Characteristics (continued)
SOT23, Very High Precision, 3V/5V Rail-To-Rail Op Amps MAX4236/MAX4237 Typical Operating Characteristics (continued)
(VCC = +5V, VEE = 0, VCM = VCC/2, RL = 100kΩ to VCC/2, TA = +25°C, unless otherwise noted.)
OUTPUT SINK CURRENT OUTPUT SINK CURRENT SHORT-CIRCUIT CURRENT vs. OUTPUT VOLTAGE vs. OUTPUT VOLTAGE vs. TEMPERATURE
80 60 20 VCC = 5V VCC = 3V 70 OUTPUT TO GND OUTPUT TO GND 50 MAX4236 toc22 MAX4236 toc23 MAX4236 toc24 60 15 40 50 VCC = 5V 40 30 10 VCC = 3V 30 20 20 OUTPUT SINK CURRENT (mA) 5 OUTPUT SINK CURRENT (mA) 10 SHORT-CIRCUIT CURRENT (mA) SHORTED TO VEE 10 (SOURCING CURRENT) 0 0 0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 0 0.5 1.0 1.5 2.0 2.5 3.0 -50 -25 0 25 50 75 100 125 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) TEMPERATURE (°C)
SHORT-CIRCUIT CURRENT DC I/O TRANSFER CURVE DC I/O TRANSFER CURVE vs. TEMPERATURE (RLOAD = 100k
Ω
) (RLOAD = 1k
Ω
40 2.5 2.5 VSUPPLY = ±2.5V VSUPPLY = ±2.5V 2.0 2.0 35 MAX4236 toc25 1.5 MAX4236 toc26 1.5 MAX4236 toc27 V 30 CC = 3V 1.0 1.0 VCC = 5V 25 0.5 0.5 20 0 0 -0.5 -0.5 15 OUTPUT VOLTAGE (V) -1.0 OUTPUT VOLTAGE (V) -1.0 10 SHORT-CIRCUIT CURRENT (mA) -1.5 -1.5 SHORTED TO V 5 CC (SINKING CURRENT) -2.0 -2.0 0 -2.5 -2.5 -50 -25 0 25 50 75 100 125 -100 -50 0 50 100 -100 -50 0 50 100 TEMPERATURE (°C) DIFFERENTIAL INPUT VOLTAGE (µV) DIFFERENTIAL INPUT VOLTAGE (µV)
MAX4236 MAX4237 NONINVERTING SMALL-SIGNAL RESPONSE NONINVERTING SMALL-SIGNAL RESPONSE
MAX4236 toc28 MAX4236 toc29 INPUT 10mV/div INPUT 0 0 10mV/div OUTPUT OUTPUT 50mV/div 0 10mV/div 0 1µs/div 1µs/div VCC = ±2.5V VCC = ±2.5V RL = 1kΩ, CL = 15pF RL = 1kΩ, CL = 15pF AV = 1V/V AV = 5V/V
_______________________________________________________________________________________ 9
