Datasheet OP77 (Analog Devices)
DescriptionNext Generation OP07, Ultralow Offset Voltage Operational Amplifier
Pages / Page17 / 1 — Next Generation OP07 Ultralow. Offset Voltage Operational Amplifier. Data …
RevisionG
File Format / SizePDF / 407 Kb
Next Generation OP07 Ultralow. Offset Voltage Operational Amplifier. Data Sheet. OP77. FEATURES. PIN CONNECTIONS
Datasheet OP77 Analog Devices, Revision: G
Next Generation OP07 Ultralow Offset Voltage Operational Amplifier Data Sheet OP77 FEATURES PIN CONNECTIONS Outstanding gain linearity VOS TRIM 1 8 OP77 VOS TRIM Ultrahigh gain, 5000 V/mV min –IN 2 7 V+ Low VOS over temperature, 55 μV max +IN 3 6 OUT TCVOS, 0.3 μV/°C max V– 4 TOP VIEW 5 NC (Not to Scale)
01
High PSRR, 3 μV/V max
-0 20
NC = NO CONNECT
003
Low power consumption, 60 mW max
Figure 1. 8-Pin Hermetic
Available in die form
CERDIP_Q-8 (Z Suffix)
VOS TRIM VOS TRIM 8 V+ 1 OP77 7 –IN 2 6 OUT 3 5 +IN NC 4 4V– (CASE) TOP VIEW
2 00
(Not to Scale)
20-
NC = NO CONNECT
003 Figure 2. TO-99 (J Suffix)
GENERAL DESCRIPTION
The OP77 has outstanding gain of 10,000,000 or more that is the need for VOS adjustment and increases system accuracy over maintained over the full 10 V output range. This gain-linearity temperature. eliminates incorrectable system nonlinearities common in A PSRR of 3 μV/V (110 dB) and CMRR of 1.0 μV/V maximum previous monolithic op amps and provides superior performance virtually eliminate errors caused by power supply drifts and in high closed-loop gain applications. Low initial VOS drift and common-mode signals. This combination of outstanding rapid stabilization time, combined with only 50 mW of power characteristics makes the OP77 ideally suited for high resolution consumption, are significant improvements over previous instrumentation and other tight error budget systems. designs. These characteristics, plus the TCVOS of 0.3 μV/°C maximum and the low VOS of 25 μV maximum, eliminates
Rev. G Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2002–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Pin Connections General Description Table of Contents Revision History Specifications Electrical Specifications Wafer Test Limits Typical Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Test Circuits Applications Precision Current Sinks Outline Dimensions Ordering Guide
