Datasheet ATtiny13, ATtiny13V - Summary (Microchip) - 6
ManufacturerMicrochip
Description8-bit AVR Microcontroller with 1K Bytes In-System Programmable Flash
Pages / Page22 / 6 — 3. General Information. 3.1. Resources. 3.2. Code Examples. 3.3. Data …
RevisionRev. 08-01-2010
File Format / SizePDF / 574 Kb
3. General Information. 3.1. Resources. 3.2. Code Examples. 3.3. Data Retention. ATtiny13
3 General Information 3.1 Resources 3.2 Code Examples 3.3 Data Retention ATtiny13
3. General Information 3.1 Resources
A comprehensive set of drivers, application notes, data sheets and descriptions on development tools are available for download at http://www.atmel.com/avr.
3.2 Code Examples
This documentation contains simple code examples that briefly show how to use various parts of the device. These code examples assume that the part specific header file is included before compilation. Be aware that not all C compiler vendors include bit definitions in the header files and interrupt handling in C is compiler dependent. Please confirm with the C compiler documen- tation for more details.
3.3 Data Retention
Reliability Qualification results show that the projected data retention failure rate is much less than 1 PPM over 20 years at 85°C or 100 years at 25°C.
6 ATtiny13
2535JS–AVR–08/10 Document Outline Features 1. Pin Configurations 1.1 Pin Descriptions 1.1.1 VCC 1.1.2 GND 1.1.3 Port B (PB5:PB0) 1.1.4 RESET 2. Overview 2.1 Block Diagram 3. General Information 3.1 Resources 3.2 Code Examples 3.3 Data Retention 4. Register Summary 5. Instruction Set Summary 6. Ordering Information 7. Packaging Information 7.1 8P3 7.2 8S2 7.3 S8S1 7.4 20M1 7.5 10M1 8. Errata 8.1 ATtiny13 Rev. D 8.2 ATtiny13 Rev. C 8.3 ATtiny13 Rev. B 8.3.1 Wrong values read after Erase Only operation 8.3.2 High Voltage Serial Programming Flash, EEPROM, Fuse and Lock Bits may fail 8.3.3 Device may lock for further programming 8.3.4 debugWIRE communication not blocked by lock-bits 8.3.5 Watchdog Timer Interrupt disabled 8.3.6 EEPROM can not be written below 1.9 Volt 8.4 ATtiny13 Rev. A 9. Datasheet Revision History 9.1 Rev. 2535J-08/10 9.2 Rev. 2535I-05/08 9.3 Rev. 2535H-10/07 9.4 Rev. 2535G-01/07 9.5 Rev. 2535F-04/06 9.6 Rev. 2535E-10/04 9.7 Rev. 2535D-04/04 9.8 Rev. 2535C-02/04 9.9 Rev. 2535B-01/04 9.10 Rev. 2535A-06/03
